-   -   3dmark11 score (gigabyte gtx 680 windforce 3x) (http://www.hardwarecanucks.com/forum/video-cards/54790-3dmark11-score-gigabyte-gtx-680-windforce-3x.html)
fc0712 June 15, 2012 04:48 PM
hey i had some problems with freezing and then i just wanted to try to run 3dmark11 again to see if it still freezes, but no i run the performance test 2 times and i didn't freeze
so here you got my score but i think my score for my graphic is very low= NVIDIA GeForce GTX 680 video card benchmark result - Intel Core i5-3570K Processor,ASUSTeK COMPUTER INC. P8Z77-V score: P9388 3DMarks
i have set the graphic to maximum performance in nvidia control panel
Motherboard: Asus P8z77-V
Processor: Intel core i5 3570k
Memory: Kingston hyper x genesis 1600 mhz ram (http://www.valueram.com/datasheets/K...D3X2K2_8GX.pdf)
Video: Gigabyte gtx 680 windforce 3x
HDD: Intel 520 240gb
PSU: Corsair AX 750
Case: Corsair Carbide 500r
Monitor: Asus Ve24H
OS: Windows 7 Ultimate
another things my ram they have been set to the right spec in bios with intel xmp but they don't show up in 3dmark 11 specs as they are configured in bios:
sswilson June 15, 2012 04:57 PM
I don't know about "very low", but it does seem a touch low.... here's my best score with a 1366 920...
NVIDIA GeForce GTX 680 video card benchmark result - Intel Core i7-920 Processor, EVGA X58 SLI Classified score: P10081 3DMarks
dustin1706 June 15, 2012 07:27 PM
Not really low at all.
NVIDIA GeForce GTX 680 video card benchmark result - Intel Core i7-3930K Processor,ASUSTeK COMPUTER INC. RAMPAGE IV EXTREME score: P10418 3DMarks
fishingfanatic June 15, 2012 10:20 PM
Video Cards
While I can't seem to bring up my results for the 980x ES 2.4Ghz @ 3.01 in either extreme or entry, the results are x2003 with a physics card and x2005 without.
Entry level without physics was 9594.
I think your score is reasonable, with a possible lower score than I would've thought, but I'm just a beginner, as I just found out how to implement a dedicated physics card.
:doh::whistle::biggrin:
fc0712 June 16, 2012 02:32 AM
but why is the spec on the card in 3d mark 11 specified as 705 mhz base clock and 3004 mhz in memory clock. when my specs on the gpu is Core Clock
Base clock: 1071 MHz / Boost clock: 1137 MHz
Shader Clock
N/A
Mem Clock
6008 MHz
dustin1706 June 16, 2012 12:02 PM
Shader Clock
N/A
Mem Clock
6008 MHz
Because 705 is the idle clock.
You have idle/full load/turbo clocks. 3Dmark reads the clockspeeds when the card is idling. If you run MSI afterburner, evga precision or a similar program, once the benchmark is done you can see what clockspeed your card went up to when it was loaded on the graph.
fishingfanatic June 26, 2012 09:13 PM
3DMark score
Wow. My scores for my daughter's system are as follows: X3189 graphics score 2935 Physics 8690 Combined 3414. The Advanced Edition 3DMark 11.
Still can't get the performance test to run. :blarg::sad::whistle: Beginner's quandry I guess, hehe.
Her system is pretty damn good with an ES 980x @ 2.4ghz oced to 3.07. Kingston now SSD, OCZ 1600Mhz with a Chiltec Ultra piezo electric cpu cooler, my old 1. I put my new Gigabyte 670 OC WindForce in it.
Windows 7 Ult 64bit. The mobo is Asus P6X58D-E. Funny thing is it's in an ATI AMD special edition case by CoolerMaster.
Time to email Furmark again.:blarg:
Well I finally got somewhere. Here's the results @ 3.07 Ghz:
NVIDIA GeForce GTX 670 video card benchmark result - Intel Core i7-980X Processor,ASUSTeK Computer INC. P6X58D-E score: P9080 3DMarks
now at 3.6 Ghz:
NVIDIA GeForce GTX 670 video card benchmark result - Intel Core i7-980X Processor,ASUSTeK Computer INC. P6X58D-E score: P9214 3DMarks
:thumb::biggrin:
elmorejohn46 June 27, 2012 07:19 AM
Your score looks fine and all the GTX-670 and GTX-680 show 705nhz but that just because it is reading the first clock it sees ,but if you look at GPU-z it will show you what it was running ,just enable the log file and you can see how high it boosted and your tempertures.
