Old June 13, 2012, 08:53 PM
Default High temps while using firefox, what do you all get?
i HAVE A 6950 CROSSFIRE AND USING A custom fan profile. It was 23C today and its still warm inside right now, and just with an online newpaper and IMDB opened in firefox both cards are averaging 53-58C with the fan around 33%-40% for those temps
That seems really hot just for a few pictures , same temps while on HWC typing this. Thats almost as hot as games, FO:NV is around 60-62C, f1 2011 and skyrim are about 63-66C and BF3 is ~66-70
whats your temps while browsing?
edit:and MSAIAB says GPU1 usage is up and down, while GPU2 us almost always ZERO, yet GPU2 is holding 55-57C while its doing nothing??????? And it always runs 5-6C cooler at idle than GPU1
GPU1 is dual fan sapphire
GPU2 is single fan sapphire (non-ref)
i7 2700k - 7950 3GB crossfire - 4GB 1866 CL8 - 1600p
Old June 13, 2012, 09:03 PM
BigPhatPaulie's Avatar
Try reseating the cooler with new thermal paste? might be the issue
FOR PONY..... that is alll
Old June 13, 2012, 09:06 PM
Jake_HT's Avatar
I'm not monitoring temps but my CPU usage doesn't go over 10% no matter how hard I browse... I think you've got some other issues.
http://jakeht.deviantart.com/
Old June 13, 2012, 09:42 PM
Adzsask's Avatar
Wow something not right there, just checked 2C higher then idle while watching 12 videos at once on my gtx 480.
Old June 13, 2012, 09:44 PM
great_big_abyss's Avatar
Yeah, watching videos online really shouldn't tax your GPU at all since there's no rendering to be done. DVD's need some decoding, but really the amount of computing power is tiny.
Old June 14, 2012, 05:47 AM
How to Disable Hardware Acceleration (GPU Rendering) in Mozilla Firefox to Fix Font Problem? - Tweaking with Vishal
Old June 14, 2012, 09:30 AM
wow thanks, as soon as I clicked OK I heard the fan power down, GPU1 temp is falling about 10C, but GPU2 is still stuck at 55C as its been for the last half hour.....even though its not loaded
Its core is running at 800, usually powers down for idle at 250MHz and ~35C, that seems like quite a temp increase (55C) just to be running at stock 800MHz
I'm going to try that now on GPU2, using the stuff that came with my silver arrow
Old June 14, 2012, 01:41 PM
Dzzope's Avatar
2 words come to mind with that.. Void and warranty..
IMO, if the first gpu decreased from the settings alone then it is some problem with sli / x-fire that is causing the second gpu to not react to this setting... dig further before voiding your warranty.
Old June 14, 2012, 04:15 PM
Don't worry, don't do anything drastic like unseat the heat sink, your temps are normal.
My trifire rig is @ 52 degrees @ 27% load browsing and it just cooled off from 80 degrees as I bitcoin mine when i am at work.
69xx card run hot.
Edit: 27% fan load not gpu load
Old June 14, 2012, 07:09 PM
gingerbee's Avatar
my answer is chrome / opera/ explorer
High temps tianfeng Troubleshooting 14 June 29, 2011 11:02 AM
Still very high temps or not? BFighter Video Cards 11 April 28, 2011 10:12 AM
Temps seem a little high... element291 Air Cooling 28 January 15, 2009 09:33 PM
High Temps BALISTX Overclocking, Tweaking and Benchmarking 20 July 14, 2008 04:32 PM
HDD, CPU temps too high? donimo HTPC Systems & Software 12 June 6, 2008 09:34 AM
