elmorejohn46,
It's always good to get the exact same card models from the same brand as in your case. Things to keep in mind also if you have encountered any problems with SLI :
1. Despite being the same model from the same company, sometimes the same video cards are not made equally. One maybe more stable than another card or one may perform better. Of course it is out of your control in terms of manufacturing, but something to keep in mind if you do have problems and may need to return one card or try the following method below to diagnose or solve.
2. I know this second fact also which I can state for reference or to help others if they ever encounter this problem. Their SLI configuration, if mix matched with another card from another brand and probably has a different clock speed, can have some problems where the frames per second will drop alot. If this is the case, test each card individually first, replace the SLI bridge if you really suspect a problem, and finally this is the MOST important, try putting the "higher clocked" card in the upper Pci-e slot instead of the bottom ones. One person I sold a Gtx 680 had this problem and I suggested he put the "higher" clocked Gtx 680 in the upper slot and the lower clocked, different brand one to the lower Pci-e slot. And voila, problem solved!
P.S.
bigFOIG, Good luck with your BST sales!
