Old June 13, 2012, 03:10 AM
Question gtx 680 single or sli?
hello i will be buying the samsung s27a950d and for that i wana ask gtx 680 single is inaf or sli will do better job for games?
Old June 13, 2012, 04:27 AM
sswilson's Avatar
I stand to be corrected, but it's a standard 1080 res monitor so I can't see needing more than one card for any application.
Old June 13, 2012, 12:29 PM
Bond007's Avatar
obvoiusly sli is better, but not required IMO. I would go for a 670 at that resolution.
Old June 13, 2012, 01:16 PM
I run a Dell U2711 at 2560 on a single 680 and I'm playing everything maxed and haven't ran into any issues FPS wise. It's been fantastic.
A single 680 will be more than enough to drive 1920 with that monitor. Or as Bond said, a 670 would also be more than enough.
Old June 13, 2012, 03:42 PM
Yep 670 is definitely enough for single monitor gaming. If you have the $$ and can find the 680 then go for it!
Old June 13, 2012, 04:01 PM
Soullessone21's Avatar
go with the 680 EVGA my EVGA and ASUS 670 were both DOA :( but both my wifes EVGA 680 SC's work perfect and they rock every game
Good Bye HWC it was great :)
Site and Forum:
http://forums.realhardwarereviews.com/index.php
If you need me the link above is where I spend my days now
Old June 16, 2012, 04:40 AM
elmorejohn46's Avatar
I would go with two ASUS Direct CU II GTX-670 or the GTX-670 Gigabyte with three fans because it will be faster and you can turn on all the extra feature FSAA 16X or you may get a bigger monitor or you might want to do a TRI- monitor setup.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
Dual 3GB 580's now, or a single 680? AmuseMe Video Cards 5 June 3, 2012 10:39 PM
SLI or Single Card? pasteberlusconi Video Cards 17 August 19, 2011 10:23 PM
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
New single PCB 295 Realityshift Press Releases & Tech News 15 June 14, 2009 01:18 PM
Single PCB GTX 295 Coming Soon... Dave510 Press Releases & Tech News 19 June 2, 2009 08:16 PM
