Old June 9, 2012, 03:55 PM
Bond007's Avatar
Originally Posted by hossdaddy View Post
upgrading to a gtx 560 would be a big jump from your 6670. Just go look at reviews/benchmarks for the 6670 and the 560. And yes I am talking about the straight 560 not the lower SE model nor the more powerful Ti.
He has a 6770 not a 6670. A 6770 is a bit slower than a gtx 460, so the 560 would be an improvement for sure, but if I was you I would go for a used 560Ti.
Old June 9, 2012, 05:13 PM
Dzzope's Avatar
There is the GTX 640.. But I've not actually read up on it at all..
NCIX US - Buy VCGGT640XPB - PNY GeForce GT 640 900MHZ 1GB 1.8GHZ GDDR3 DVI VGA HDMI PCI-E Video Card - PNY Technologies Inc - Great price and fast delivery
Old June 9, 2012, 06:38 PM
Bond007's Avatar
Originally Posted by Dzzope View Post
Trades blows with a 6670, so its slower than a 6770. Currently overpriced
http://www.tomshardware.com/reviews/...view,3214.html
Old June 10, 2012, 09:10 AM
fireXtract's Avatar
I actually have a 6770 that otherguy mistyped it
Old June 10, 2012, 09:20 AM
I know you got that upgrade itch, but I'm going to recommend you hold off if you want a real upgrade.
You have very few options, the 6770 isn't half bad a card at this point in time.
I'd honestly scrap this upgrade and save up a little more to get a better card. It will last you longer and you'll be happier in the end. You might even be able to hold off until the midrange 600 series comes out, pick up a used 560ti or 570 even for super cheap.
Old June 10, 2012, 07:11 PM
Dzzope's Avatar
Agree with Lark.. your budget is going to make an upgrade not really worth it.
Save for a bit longer and try find someone to sell your card to when you do have some more funds (and the mid range 660 and 650 cards are released) and then make a bigger jump
Old June 11, 2012, 09:54 PM
fireXtract's Avatar
Ok thanks i think i will wait then!
EVGA GTX580 Vanilla Card mattlef Price Check 4 December 21, 2011 08:38 PM
The new EVGA dual GF110 card!!! Delavan Video Cards 24 January 12, 2011 10:08 PM
Wondering about having 2 video card: ati AND nvidea on same motherboard NeitNJ Video Cards 10 July 22, 2009 04:07 PM
nVIDEA Geforce 6200 - Driver issue??? mattydies Video Cards 20 February 29, 2008 12:07 PM
NVidea 8800 series OC tutorial Scratch Reviews & Articles from the Web 2 May 18, 2007 11:56 AM
