<~----> Best graphics card for older dual core? - Hardware Canucks
Old June 8, 2012, 06:01 AM
Default Best graphics card for older dual core?
Hello I want to upgrade my graphics card I currently have a RADEON x600
my specs:
Intel Pentium 940 Dual core 3.20ghz socket 775
2GB DDR2 ram
asus motherboard with two PCI 16x slots
400w power supply
windows 7 64bit
I was thinking a GeForce 8600 or GeForce 210 ?
Old June 8, 2012, 06:28 AM
What's your budget / where do you shop, and why do you want a new graphics card (GPU)?
Also if you get a new GPU, do you plan to keep it and then build a new computer around it in the future (e.g. after saving some more money)?
Old June 8, 2012, 07:35 AM
$60 budget, i shop at NCIX.ca and i want a new one so i can run more games, the card i have now can run most games i play but i would like to run a bit more, im not talking like BF3 but newer CoD's. and i would not keep it around if i upgrade/build a new PC
Old June 8, 2012, 08:08 AM
great_big_abyss's Avatar
I have an ASUS X1950PRO lying around somewhere. If I can find it I can send it to you. You pay shipping, that's all.
ASUS - Graphics Cards- ASUS EAX1950PRO/HTDP/256M
EDIT: That card is a DX9 card. But if you're still running WinXP, then you're limited to DX9 anyways, so that wouldn't make a difference.
If you want something a little more modern/powerful, you could look at a new GT430 which sells for about $45 after MIR.
Here is the link to the product on NCIX.
Here is a review on the card from Guru3D
My Rig: Z77A-G45; 3570K; H80i; 2x4GB Kingston HyperX 1600Mhz; ASUS GTX660 SLI; 2x 128GB Crucial M4 SSD; 500GB WD Black; PC&C 750W PS; CM 690II Advanced;
Son's Rig: M5A97; 1055T; CNPS20LQ; 2x4GB Corsair Vengeance 1600Mhz; ASUS GTX650Ti Boost; 80GB Intel 520 SSD; 320GB WD Black HDD; SPI 700W; Bitfenix Shinobi;
HTPC: F1A75-M PRO; A6 3670K; Hyper 212+; 2x4GB G.Skill Ripjaws 1866Mhz; Sapphire HD5870; Corsair 60GB SSD; 1TB WD Green; 2x 2TB WD Green; SPI 450W;
Old June 8, 2012, 11:41 AM
Hehe, you're in luck, I just saw this on the BST.
http://www.hardwarecanucks.com/forum...tml#post633164 for $50
I don't think you'll find a better GPU for your system than this. Playable framerates in Crysis, and it absolutely destroys CODMW
Old June 8, 2012, 11:43 AM
Adzsask's Avatar
for a $60 budget, find a used GTX260,275,or 280, maybe even a used GTS450.
Old June 8, 2012, 01:55 PM
Soultribunal's Avatar
You might have missed it but he is running a 400W supply with far from a power efficent 940 Duely. Not a good idea to put such a power hungry card in there, save the GTS450...
-ST
Old June 8, 2012, 05:08 PM
You would need a power supply upgrade to handle a 4850. I would say GT430, HD 5570, HD 4670, GT240, HD 5670. Those cards should be a decent upgrade for you, run on your current power supply without issue, and keep you in or a touch over budget. Take a look around and see what deals you can find...maybe find one used to save a few extra dollars.
EDIT: just a quick look and I found refurbished hd 4670 for $41 with free shipping. It would be an option.
Newegg.ca - Refurbished: VisionTek 400623 Radeon HD 4670 1GB DDR3 PCI Express 2.0 x16 Video Card
Newegg.ca - Refurbished: VisionTek 400530 Radeon HD 4670 1GB DDR3 PCI Express 2.0 x16 Video Card
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
Old June 8, 2012, 09:30 PM
I think he'd be fine with his 400W. I ran a 5830 for a year with a 400 watt with an older Phenom quadcore, which wasn't exactly a miserly processor when it comes to power. The recommended PS for the 5830 was 450W, just like the 4850. Only difference is that the 5830 had one 8-pin and one 6-pin connector, while the 4850 only has one 6-pin. I think he'll be fine with the PS that he has.
Old June 9, 2012, 11:48 AM
hossdaddy's Avatar
this should do nicely.
Gigabyte Radeon HD 6670 800MHZ 1GB $73.00 - $15 mir
Main System:
i5 3570k @ 4.6ghz | GA-Z77X-UD3H | Gigabyte GTX 670 | 8gb Redline 1600mhz | CM 690 | Logitech G9x | Mushkin Cronos 120gb ssd | Benq 24" | CM Hyper 212+ | Seasonic 750w | X-Fi Titanium | Sennheiser 350 | Razer blackwidow | Win 7 64-bit
Backup System:
AMD X2 7750 BE @ 3.0G | Asus M3A78-CM | 2x2gig 800mhz 4-4-4-12 | SB LIVE | Samsung 22" | Asus 9800gt | Antec NEO 620w | Logitech G5 | ThermalTake Matrix | Arctic Cooling Freezer 64
Tags
940 socket 775 x600 300w
Sapphire Announces New HD 6970 Graphics Card with Dual-BIOS and Dual-Fan Cooling Sam_Reynolds Press Releases & Tech News 1 November 1, 2011 11:50 AM
Zotac Plans GeForce GTX 460 X2 Dual Chip Graphics Card FiXT Press Releases & Tech News 22 October 28, 2010 08:57 AM
ASUS Dual GTX 480 "MARS II" Graphics Card Spotted FiXT Press Releases & Tech News 26 July 19, 2010 01:18 PM
ASUS Designs Monster Dual-GTX 285 4 GB Graphics Card MonsterSound Rumor Mill 24 November 15, 2009 04:25 PM
ASUS Designs Own Monster Dual-GTX 285 4 GB Graphics Card cadaveca Press Releases & Tech News 15 May 29, 2009 08:50 PM
