-   -   Windforce 7970 vs Windforce 670 (http://www.hardwarecanucks.com/forum/video-cards/54552-windforce-7970-vs-windforce-670-a.html)
JoeOnePack June 6, 2012 07:20 PM
I just picked up a Windforce GTX 670 yesterday. a Windforce 7970 popped up for the same price.
What would you choose and why? I plan on OC'ing it. I will also be using a 2560x1440p monitor.
Thanks
Eluder June 6, 2012 07:43 PM
I would think the 7970 will perform better overall once you start overclocking it.
The 670 however might be quieter because of the nature of that GPU.
If it's the same price and you don't think you'll ever go SLI/CF, I'd probably go for the 7970 because of the additional VRAM.
BigPhatPaulie June 6, 2012 07:54 PM
For the same price? Kinda hard to say but the 670 is as fast until you OC then it falls a bit behind but not nearly enough to make you change your 670 to a 7970
JoeOnePack June 6, 2012 10:28 PM
Even for the extra 1GB Vram? :ph34r:
BigPhatPaulie June 7, 2012 06:29 AM
I personally haven't read into it that much but I think 2gb is more than enough for one monitor. I would just keep the 670 unless its somehow too slow or you actually use all the ram on the card
Pabz0r545 June 7, 2012 10:49 AM
I'm no expert but I believe the VRAM is not a proper judge? Maybe for multi monitor it is but I don't know. I'm just saying this because for example a 6970 has 2gb of vram and a gtx 570 has 1.28gb where as they give roughly the same performance and are in direct competition with eachother.
On a side note why is it that Nvidia's less VRAM performs as well as AMD's more VRAM?
great_big_abyss June 7, 2012 11:36 AM
You would only need 3GB of VRAM if you're running 3 or 6 monitors. For a single monitor, even a 27" or a 30", 2GB will be more than enough video memory. Hell, even 1GB is most likely enough for any single monitor (30" might be pushing it though).
Amount of video memory is NOT indicative of card performance. I just bought a 5450 that says 1GB on the box, but in actuality the card has 1/20 the performance of a 6850. So in otherwords, even though it's 'a 1GB video card' it's actually incapable of running even the most basic game. Another example: the GTX680 2GB blows the 7970 3GB out of the water in almost every metric. The only place it might fall short is when running two or three of them together in order to drive three or six monitors.
You want to look for is the number of graphics cores, ROPs, and texture units, as well as the overall efficiency and power consumption of the card. Look at the reviews to determine which card suits your needs best.
GTX670 Review
However, since you've already purchased a 670, all this should be moot point, right?
JoeOnePack June 7, 2012 05:38 PM
Well, its only moot until I sell it and buy the 7970. :haha:
I do plan on running 3 monitors, but only the Catleap 1440p for gaming. Is this a game changer?
GTX670 Review
great_big_abyss June 8, 2012 08:27 AM
It's only a game changer if you're gaming on three large monitors (27-30"+). If you're running desktop on 2 monitors, and gaming on your center monitor, you'll be fine. You won't even come close to utilizing all of your Vram.
