Old June 5, 2012, 02:22 PM
Originally Posted by great_big_abyss View Post
Which is why I assumed it was a 7970 lightning.
Oh my goodness. I am having a backwards day. I mean a Gigabyte GTX 670 Windforce OC vs a Reference 7970.
Sorry!
Old June 5, 2012, 06:47 PM
JD JD is offline
I must say, my GTX690 tears through everything at 2560x1440. Maximum settings, maximum AA, AF, the whole she-bang!
...but since you're looking at the ~$400 range, I would go with the GTX670. ATI's driver support seems abysmal right now.
Old June 5, 2012, 06:54 PM
Well, good call. I just picked up the Gigabyte GTX 670 Windforce OC an hour ago. Can't wait to start my build tonight.
Old June 5, 2012, 06:55 PM
JD JD is offline
Awesome! Be sure to post some pics once you get it all up and running
Old June 6, 2012, 08:26 PM
rjbarker's Avatar
Yep my 2 x 580 Ultra 3GB smokes through anything at same Res.....will be skipping 6xx Series altogether ;)....next investment for me will be GTX 7xx Series.
Classified Ultra SLi "Procyon"
http://i30.photobucket.com/albums/c3...2/DSC02888.jpg
http://i30.photobucket.com/albums/c3...2/DSC02889.jpg
Evga 4.2 Ghz Club....
Old June 7, 2012, 07:29 PM
Well, I picked up a GTX 670 Windforce OC 2GB. I have the option of replacing it with a 7970 Windforce OC 3GB.
If I want to power the 1440p display for gaming and two other monitors for other stuff, will the 670 cut it or am I better suited for the 7970 3GB?
Old June 7, 2012, 08:25 PM
Phill's Avatar
I run 2560X1440 with a windforce 670. I would like a little more horsepower to be honest.
As far as vram 2GB is plenty. I haven't really seen usage of the frame buffer go over 1.2GB TBH. I would stay with the 670 I guess but really it is a toss up. I doubt the 7970 would be tangibly any better.
Old June 7, 2012, 08:27 PM
Phill's Avatar
Yes the 670 would do just fine.
  #19 (permalink)
Old June 7, 2012, 10:46 PM
I think the 7970 will give you SLIGHTLY more raw power... but given the issues (especially very recently) with AMD's drivers and how close the performance is I went for a 670 too..
Even though the 3 free games does make it cheaper than a 670 but I think I might only really play 1 / 3..
graphics card power consumption marciobs65 LinusTechTips Q&A 5 April 30, 2012 05:46 PM
Which Card (Screen Resolution) fuzman Video Cards 5 January 5, 2012 04:32 AM
AMD Extends Graphics Performance Lead, Launches World's Fastest Graphics Card? Again! FiXT Press Releases & Tech News 2 March 8, 2011 02:32 PM
Asrock N68-S UCC with Power color HD5670 512 graphics card cl0ud CPU's and Motherboards 4 November 19, 2010 07:36 AM
SPARKLE Announces GeForce GT 220 1GB DDR2 Graphics Card With Low Power Passive Cooling Design mikellini Press Releases & Tech News 6 May 28, 2010 11:24 PM
