Old June 4, 2012, 12:08 PM
fishingfanatic's Avatar
Smile Physx
Ok folks I need help. Never set up a dedicated physx card b4.
I'll be trying it on my daughter's system. Specs are: 980x ES base clock 2.4 oced to 3.07.
Ultra chiltec cooler, Asus P6X58D-E mobo, 6gbs of OCZ 1333 ram, Kingston Now SSD for OS.
Main card is an EVGA GTX 570. We have a GT 520 to use for physx.
I've tried to find help online and even the Nvidia site doesn't have the info I need. Waiting for a response from
support.
I figured the experts on here could help me a little quicker. Simply need a site that explains how to set it up.
Thanx in advance!!!
Edit: Just got a reply from Nvidia Support. WOW, that was quick....
I could still use any helpful info, just in case.
Wow, Do I feel f#%^#g stupid.
What a difference. Had to do it twice, as it picked up the hardware but wouldn't recognize it????
Pulled, re-installed, recognized on 2nd installation??? wtf. At least it's working!
Mods plz delete this silly thread.
Old June 4, 2012, 12:42 PM
lowfat's Avatar
I think a GT520 is likely too slow to pull off PhysX. I am willing to bet your framerate will actually be lower than w/ just the GTX570 alone.
I am not able to get my GTX680s to POST so I can't tell you exactly where in the Nvidia control panel the PhsyX options are. But it should give you a choice on which card you want to to the PhsyX processing on.
The Crippled God WIP
Queen of Dreams WIP
Big Lian Li
Complete
Forever Alone Complete
Old June 4, 2012, 12:57 PM
Smile Physx
Thanks LF. Going to run #D Mark 11 and see.
Hope you get those 680s running cherry. Shouldn't take you too long with your knowledge.
Old June 4, 2012, 01:38 PM
BigPhatPaulie's Avatar
Yea a lot of users have found that running a separate physx card isn't all that beneficial. A single 570 will most likely do better than the 570/520 combo. However its still a cool idea and let us know how it works both ways if possible?
FOR PONY..... that is alll
Old June 4, 2012, 04:26 PM
Bungwirez's Avatar
Originally Posted by lowfat View Post
I am not able to get my GTX680s to POST.....
This make me sad
I'm Bungz. mostly I bung things up. sometimes I play a doctor on TV.
Old June 4, 2012, 08:18 PM
Smile Video Cards
Well I ran 3D and got the same results with the 520 in place and out.
I had to run it using an old monitor as the tvs were occupied. Not sure how much dif that would make, as the old monitor is a mere 1280x1024.
Thought I got rid of that piece of c$@p. Guess it came in handy after all. Time to hunt down a decent monitor.
I did continually receive error messages with both scenarios so I have to contact Furmark.
That should be interesting.
Old June 4, 2012, 09:14 PM
Maybe dumb question but since I have a red team card (7950) is it possible to still use an nvidia card for physx Thanks!
Comp1 (Mine) : ASUS P9X79 LE, 3960X, 16GB Corsair Vengence 1333, PNY 770 4GB, OCZ Vertex3 240GB, OCZ Vertex3 480GB, 600GB VelociRaptor, Corsair 1000HX, Cool Master Cosmos 2
Comp2 (Wife's) : ASUS Sabertooth P67, i7 2700K, 8GB Corsair Vengeance 1866, 1TB HD, 2TB HD, EVGA 660, Corsair 1000HX, HAF 922
Comp3 (Kids) : ASUS P8P67 Pro, i7 2700K, 8GB 1866 GSkill, Gigabyte 770, Crucial M4 120GB, OCZ Vertex3 240GB,1TB WD Black, Antec 850W, Antec 120
Old June 4, 2012, 10:05 PM
Dzzope's Avatar
Possible yes.. Have a search here there is a few threads about it I believe.
Old June 7, 2012, 06:29 PM
Smile Physx
Ok folks. I like the idea of physx, and the 520 just isn't cutting it just like Lowfat mentioned it would.
Though I have a 570 in that pc for the main card, what would you recommend for a physx card?
There's a 450ti available, would that be good enough?
Old June 7, 2012, 06:44 PM
MARSTG's Avatar
Even an old 9800gt should cut the mustard
PhysX Wurmer Video Cards 9 January 6, 2011 06:16 PM
PhysX r0k0 Video Cards 8 January 23, 2010 09:00 PM
PhysX help Varroa Video Cards 2 December 18, 2009 12:15 PM
Physx kendallcschm Video Cards 0 December 6, 2009 07:29 PM
PhysX with ATI? ToXic Video Cards 43 August 13, 2009 06:42 AM
