<~----> Physx - Page 2 - Hardware Canucks
Old June 7, 2012, 06:51 PM
fishingfanatic's Avatar
Smile Physx
Ok, thanks MARSTG. Figures, sold both my 9800 GX2s. Perhaps I'll use the wife's PNY 465 when I get my next card.
That should work pretty good as the rating is still 7.6 on WEI, though I don't generally go by their ratings.
supaflyx3's Avatar
Probably 550ti at the very lowest, but honestly its a waste of money.
Old June 15, 2012, 10:29 PM
Smile Physx
Ok. Recently ran 3D Mark again using a 465 for physics. It still won't run performance.
Extreme with the 465 comes in at X2003. Without, X2005
Entry with only the 570 comes in at E9594. IT wouldn't let me run a custom setting. The only change was bumping up the display resolution to 1920x1080.
Might have to re install my patches according to tech. this should allow me to run performance in either scenario and allow custom settings to run.
Old June 16, 2012, 01:11 AM
and you need to specify in the global settings in Nvidia control panel who will run the physx. Make sure is the second card. Usually a setup like this is allowing the main card to focus on just the rendering with the second card to jump in only for the physx calculations. And maybe you just need a registered version of the test to make the changes you want. My picture shows the panel, but you need to select the second card in there, not leave it on Auto. I will ran the test myself, with 2 x 4650 in crossfire alone and then plus the GT430 see if there will be any difference. I have a registered version of the test so I can choose whatever resolution I want.
PhysX Wurmer Video Cards 9 January 6, 2011 05:16 PM
PhysX r0k0 Video Cards 8 January 23, 2010 08:00 PM
PhysX help Varroa Video Cards 2 December 18, 2009 11:15 AM
Physx kendallcschm Video Cards 0 December 6, 2009 06:29 PM
PhysX with ATI? ToXic Video Cards 43 August 13, 2009 06:42 AM
