Old June 3, 2012, 09:30 AM
AmuseMe's Avatar
Default Dual 3GB 580's now, or a single 680?
Needing to get my rig up and going before Xmas - I hope! The only thing I really need at the moment that cost (a lot) are the video cards. I'm running SLI regardless. My friend is upgrading from dual 3GB GTX 580's right now with AquaComputer blocks, and will be upgrading to dual- GTX 690's in the coming weeks.
My video cards will be watercooled with either a HeatKiller or Aquacomputer FC block.
He is selling the 580's for average used price + $65/block.
Opinions?
I should say now, that I don't plan on really ever running multiple monitor set-ups
I'll probably only ever run at 1900x1200. Would a GTX 680 just be better than?
Old June 3, 2012, 09:43 AM
For that resolution I would think a single GTX 680 would suffice...
Old June 3, 2012, 10:06 AM
Definitely the single GTX 680 at that resolution.
Old June 3, 2012, 02:25 PM
AmuseMe's Avatar
Anyone know if the 4GB GTX680 fits FC blocks? Id assume not...
Old June 3, 2012, 08:00 PM
rjbarker's Avatar
You dont need 4GB VRAM for that Res, perhaps you can pick up your buddies 2 x 580 3GB Cards for a reasonable price, would be worth considering.
Firestrike Extreme: 21.452
MARK 11: 32.530
Old June 3, 2012, 10:39 PM
AmuseMe's Avatar
1GB for my res. 3GB for my e-peen
Single vs Dual Link DVI (argh!) hfxmike Video Cards 23 June 2, 2011 06:18 PM
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
Going from dual 4870x2's to a single GTX 580? implosion222 Video Cards 26 November 29, 2010 07:15 AM
Need help with my dual rad in a single loop jusdrink Water Cooling 33 June 20, 2009 03:43 AM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
