Old May 15, 2012, 11:20 AM
Default 6950 temps
I can keep both of mine under 70C almost always, in BF3 65-68 is about the norm, the fans are set to about 58% @75C
But in metro2033 I'm hitting 75-76, its usually around 72, I don't want to turn up the fans any more really, but I definitely don't want over 75C, I want these to last me a good while.
Whats the hottest you guys let yours get too?
i5 2500k - 7950 3GB crossfire - 4GB 1866 CL9 - 1080p
Old May 15, 2012, 12:09 PM
maverick_brent's Avatar
seen my reference (with a 6970 shader unlock and a mild oc ) hit 101C before...i expirmented with cleaning, cable managment (mine is always pretty good) and everything for about 4 days...at which point i tore the hsf off, and reapplied with mx2...dropping it from 101c to about 60-75(unsure tbh)...none the less, it needs to have some ic7 put on it with another cleaning...
Old May 15, 2012, 01:18 PM
dandelioneater's Avatar
A TIM change will give you a noticeable improvement in temps. MX-2 or AS5 properly applied will be noticeably better than the goop they slop on at the factory. AS5 on my 480 saw about an 8 degree drop in temperatures.
Old May 15, 2012, 02:14 PM
well I think I used arctic silver on the 1st 6950. But I've heard people say that voids the RMA/warranty, is that right?
Old May 15, 2012, 02:37 PM
nasrott's Avatar
waterrcool it and you'll be 45 under load in bf3, my 7970 was that temp (75) till the aqua, about a 30' drop
Old May 15, 2012, 03:12 PM
I'm not sure. If there are any 'void if removed' stickers on the screws or heatsinks that need to be broken to remove the heatsink then probably.
Old May 16, 2012, 08:27 AM
before summer really kicks in I should take my rig apart for full dusting/vacuuming, I might do it then. No money for watercooling, my temps seem good and we have a short summer...
Old May 16, 2012, 09:47 AM
Adzsask's Avatar
As long as you put the stock cooler back on before an RMA they don't care, also EVGA and MSI allow you to do things to your card, as long as it is returned to stock before returning.
Old May 16, 2012, 09:49 AM
I never had any warranty stickers or anything when I took mine off
Old May 17, 2012, 08:50 AM
Gcards run hot, and run hotter than cpu's. 75C is nothing crazy and I wouldn't worry about it. Don't think you'll have any problems with that card lasting you until your next upgrade
RMA: 6950 2gb vs 5870/6950 1gb xilocient Video Cards 10 April 27, 2012 08:09 PM
Sapphire Launches Radeon HD 6950 TOXIC Edition, Fastest HD 6950 Yet Sam_Reynolds Press Releases & Tech News 2 August 5, 2011 02:25 PM
Safe VRM Temps for Radeon 6950? Eluder Video Cards 2 June 26, 2011 01:26 PM
Hd 6950 ? Hexofire Video Cards 5 March 29, 2011 02:43 AM
CPU temps vs Core temps sloth CPU's and Motherboards 13 October 19, 2008 12:34 PM
