Old April 4, 2008, 04:34 PM
biff's Avatar
Default Stability testing GPU O/C
Just wondering how long ATItool artifact scanning has to run error free before I can call it a stable clock? I read some where that 4 minutes is a very good indicator since they have found that if it goes that long error free then it'll go forever. So far my experiences seem to support that but I want to run a longer test just to make sure.
i7 4790K @ 4.8GHz w/EK Supremacy Evo
MSI z97 Gaming 5
2x 8GB Gskill Sniper 2133 @ 2400MHz
EVGA GTX 280 (SC?)
OCZ Gamer Xtreme 600W PSU
Still rockin' the Cooler Master Cosmos on water
Old April 4, 2008, 04:44 PM
sswilson's Avatar
Longer is always better to ensure stability.
After my experience with overheating VRMs on a Sapphire 1950pro I always do at least 1/2 hour on my gpu as it sometimes takes the voltage ccts a while to overheat (on the sapphire it was 18 minutes under load).
Old April 4, 2008, 05:06 PM
3.0charlie's Avatar
It all depends on the cooling method. When I check a GPU with AtiTool, I keep a close eye on the temps, both GPU and case. If the clocks are left untouched, that the temps have stabilized and still no errors are found, then I call it stable. Usually takes about 10 minutes + 5 minutes of stable temps.
If I raise the clocks, it's just a matter of repeating the testing process.
Hydro-Quebec is salivating...
Old April 7, 2008, 08:22 AM
biff's Avatar
I had it running for hours and hours so the temps were stabilized, it actually took about 30 to 40 minutes to get there mind you it was a very small increase past 15 minutes worth. Maxed out @ ~47C.
The clocks that I settled on I found that it it would get an error about every 45 to 60 minutes, so that's what, one errant pixel about every hour? I can live with that. OTOH VRAM clocking was a complete no go. Any "worthwhile" increase would start corrupting the fuzzy box and inevitably snowballed into a system crash. I only have those stick-on ransinks and two of those were cut down because of interference with the tubing from the Maze5. I wonder if better cooling would make any difference.... Somehow I doubt it.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old April 7, 2008, 11:39 AM
cdn_Madrach's Avatar
Maybe position a fan to blow on the ramsinks. Without a fan on your gpu you've already lowered the airflow around them unless your case airflow blows accross them. My 1900's with switech blocks and ramsinks used to heaten up alot because of lack of airflow. I put a small fan in front of cards to blow across them and now they are fine. Just a thought.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
Silverstone Strider 1kw modular
4870x2
Ocz Vendetta 2
Top deck Tech Station
Samsung dvd
Old April 7, 2008, 12:26 PM
biff's Avatar
The video card gets a reasonable amount of air from the fan on the rad just below it as you can see in the pic. You can also see how much I needed to trim the ramsinks to make room for the tubes. I might try to make a one piece cooler for the vram but it appears that most can get too far past 1000MHz with Qimonda Ram and mine is 1010MHz stock so maybe there isn't anymore to be had. I wish I had of recorded the ram type before I stuck on the ramsinks.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old April 7, 2008, 01:59 PM
3.0charlie's Avatar
I must say - again - how your case looks: a million bucks.
As for your Vram, just jerry-rig a small fan next to the sinks, and bench again. I don't think that the airflow coming from the mid-case rad is enough to cool the sinks. It's quite far actually.
Try it, you never know.
Old April 7, 2008, 02:54 PM
biff's Avatar
Yeah on second thought maybe i'll do that. If it does turn out to make a difference then I'll look into doing something more permanent for vram cooling.
MSI z97 Gaming 5
EVGA GTX 280 (SC?)
Old April 7, 2008, 03:36 PM
If it does work ... one of those antec spotcool fans would do the trick. Oh and I agree with Charlie...awesome job on the build.
Intel e8400
Asus P5q pro
Mushkin Redline 4gb
4870x2
Ocz Vendetta 2
Samsung dvd
Old April 7, 2008, 05:29 PM
vinister's Avatar
I have nothing useful to add other than you make me wish I had bought the huge cosmos instead of my teenie tiny hush. And great job on the build it looks perfect ;)
Mobo: DFI 790X-M2R
Proc: AMD PHENOM X3 720
Ram: OCZ Platinum 2X 2GB @ 1066
VIDEO: 3 x Visiontek HD3870
