Old May 14, 2012, 11:45 PM
Originally Posted by Arinoth View Post
The 580 SLI will beat out the 680, especially with the extra video ram. Only catch is you probably won't ever see it use more then 2GB per card unless you're running 3 monitor gaming.
right, if the price is right, 580sli is a beast, it can easily keep every game I can think of at +60fps @1080p
i7 2700k - 7950 3GB crossfire - 4GB 1866 CL8 - 1600p
Old May 15, 2012, 12:09 AM
Originally Posted by ottawaMayn View Post
just dont forget about the microstuttering issue.
it does exist, as wierd a phenomena as it is...some gamers have huge gripes with it.
here's a good read about it: http://www.tomshardware.com/reviews/...fire,2995.html
that shouldn't deter you from sli'ing...but if your finicky, you may be upset with the results.
good luck
micro-stuttering is only really an issue with lower end graphics cards in SLI. Nvidia almost never has this problem with their higher end cards.
Old May 17, 2012, 07:57 AM
IMO get the fastest single card you can afford, and then you can always SLI/Crossfire later.
Old June 1, 2012, 08:56 PM
rjbarker's Avatar
Uh...try 2560 x 1440.. ;)
Firestrike Extreme: 21.452
MARK 11: 32.530
Old June 2, 2012, 05:23 AM
Arinoth's Avatar
Or better yet 5760 x 1080, that's another resolution that begins to bring cards to their knees.
Here I am: here I remain
Old June 3, 2012, 07:58 PM
rjbarker's Avatar
Yeah I've been running SLi 580 Ultra 3GB Cards for about 5 months now, Nothing holds em back at 2560 x 1440......the plus with these cards is the 90mm Fan, due to the size, I never have to set the Fan speed higher than 45%, obviously very quiet with very good Temps. Personally I'll be skipping the 6 Series altogether.....which isnt like me at all ;)
MARK 11: 32.530
Single vs Dual Link DVI (argh!) hfxmike Video Cards 23 June 2, 2011 06:18 PM
Single Loop or Dual Loop? Pump enough for single? MattC Water Cooling 5 May 31, 2011 07:19 PM
Going from dual 4870x2's to a single GTX 580? implosion222 Video Cards 26 November 29, 2010 07:15 AM
Need help with my dual rad in a single loop jusdrink Water Cooling 33 June 20, 2009 03:43 AM
Single rad $$$ > Dual rad $$$ why? frosty Water Cooling 9 July 16, 2008 03:39 PM
