Old May 15, 2012, 06:18 AM
Trial Member
Not all the graphics cards are upside down, all the high-end VGA have 2 types, and by high-end, that means they are calculated and design properly.
1/ If you want to use the fans to suck in the air for cooling off, that's when the card is upside down, cause heat rises, all the cool air is at the bottom.
2/ If you want to exhaust the hot air that your card produces, you turn it upward, basic stuffs.
Old May 15, 2012, 07:07 AM
crazyea's Avatar
Heat rises. If the cooler was on top it would have to suck the air downward.
Old May 15, 2012, 08:06 AM
"Quote This..."
Then PC's got louder and hotter and they moved from desktop to tower cases. Still haven't changed the atx standard board design though.
Old May 15, 2012, 09:43 AM
crazyea's Avatar
With my FT02 my gtx 680's fan is on the side...
Old June 7, 2012, 07:06 PM
I've got the Silverstone Raven RV02 case and the cooler faces me
This case has shifted the mobo 90 degrees, so the hot air exhausts out the top of the case.
graphics card help biagio1661 Video Cards 11 October 26, 2011 11:46 AM
Intel HD Graphics with Graphics Card MoUnit CPU's and Motherboards 4 August 6, 2011 03:54 PM
AMD Extends Graphics Performance Lead, Launches World's Fastest Graphics Card? Again! FiXT Press Releases & Tech News 2 March 8, 2011 03:32 PM
Installing QP-Res upside down? sswilson Water Cooling 22 February 22, 2009 06:48 PM
