<~----> NVIDIA GeForce GTX 670 2GB Review Comment Thread - Page 3 - Hardware Canucks
  #21 (permalink)
Old May 10, 2012, 07:48 AM
Thanks for the review, SKY.
The overclocking results for the 3rd party 670s should be interesting: do you get better OC from longer cards (e.g. Gigabyte) because the components are more spaced out for cooling, or worse OC results because some of the traces would be longer? When that review comes out I'll definitely jump straight to those results of short PCB vs longer PCB.
I'm still waiting for a "midrange" card from this lineup that will go against the Radeon 7850 (somehow I'm gaming on my backup 7900GS!), although seeing this review and the 680's review, it should be another slaughter when that card comes out.
  #22 (permalink)
Old May 10, 2012, 07:57 AM
Grampa's Avatar
Thanks for the review!
Talk about great bang for the buck!
I wonder what a GTX 660Ti might do in comparison to the rest now
  #23 (permalink)
Old May 10, 2012, 07:58 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
Overclocking is so different with these cards that you almost have to throw preconceptions out the window. Since the overclocks are based upon Boost speeds, if you give the ASIC excess TDP headroom (in other words, getting it to run cooler) it will Boost higher based upon your increased offset. As such, any card with an upgraded cooling assembly will naturally achieve higher clock speeds than a reference design. This isn't due to PCB traces or even component selection as those items will only come into effect when you are pushing the upper limits of the architecture through exotic means of cooling.
Considering the performance of the GTX 670, I'd predict that any GTX 660 would match or potentially beat the HD 7950. I think you would have to go downmarket in NVIDIA's lineup (ie: potential GT 650) for a card that would compete with the HD 7870 and HD 7850.
  #24 (permalink)
Old May 10, 2012, 08:04 AM
Great price considering the performance you're getting!
  #25 (permalink)
Old May 10, 2012, 08:27 AM
dandelioneater's Avatar
AMD has their work cut out for them this summer/fall retooling their architecture to be competitive with Nvidia. ATM they are not.
  #26 (permalink)
Old May 10, 2012, 08:38 AM
Keywork's Avatar
I'm sure these will sell like hotcakes, but I disagree with the comment regarding these becoming the new 8800gt's. No way at their current price. Once they release the 660 Ti, or anything around the $250 to $300ish mark, that's when s**t will get real. Great review once again though.
Friends don't let friends use onboard video.
  #27 (permalink)
Old May 10, 2012, 08:43 AM
Jebusman's Avatar
So what you're saying is,
Make Cold, Go Fast.
  #28 (permalink)
Very true, but Nvidia still has no mid-range cards in the 600 series. The 560Ti/560 are still great, but AMD have the better performance/watt in that area. Also there are no low end Nvidia cards I would buy or recommend (nothing below the 560). For anything sub gtx 560 I would recommend AMD.
The rest of this line-up can't get here soon enough. Hopefully the 660 gpu design can hold true to the performance/cost/power consumption trend that its big brothers have laid out before it.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
  #29 (permalink)
Old May 10, 2012, 08:47 AM
Eldonko's Avatar
Hardware Canucks Reviewer
Price / perf ratio on this is win. Great review :)
  #30 (permalink)
Old May 10, 2012, 08:57 AM
SKYMTL's Avatar
Make Cold, Go Fast.
Bingo. In some cases, you don't even need to up the Boost Clock. A cooler running Kepler card SHOULD boost higher by itself to begin with. But by that same rule, a hot card will NOT provide the same performance.
NVIDIA GeForce GTX 690 Review Comment Thread SKYMTL Video Cards 103 July 23, 2012 01:02 PM
NVIDIA GeForce GTX 550 Ti 1GB Review Comment Thread SKYMTL Video Cards 26 June 24, 2011 08:25 AM
NVIDIA GeForce GTX 560 Ti 1GB Review Comment Thread SKYMTL Video Cards 62 January 27, 2011 06:20 AM
NVIDIA GeForce GTX 570 Review Comment Thread SKYMTL Video Cards 82 December 14, 2010 07:50 PM
Comment Thread for NVIDIA GeForce GTX 470 SLI Review SKYMTL Video Cards 48 April 19, 2010 01:49 PM
