Originally Posted by raghu78 |
The problem here is that you are quoting Fudzilla. TPU got their info from Fudzilla.
I know you don't want to hear this but the truth of the matter is that NVIDIA stopped high end Fermi production for the GeForce line right before the New Year. The event that some sites talk about was the work stoppage for Workstation and HPC derivatives. They just got their info wrong.
I loaded Operation Swordbreaker and played again on my Radeon HD 6950 with Ultra MSAA 4X at 1080p. I waited till the initial loading and non interactive portions completed and fps stabilized in fraps. I saw till I got to the discussion table fps in low 30s and sometimes high 20s. Similarly later in the level in the first fight in the parking garage fps was in the 30s and occasionally went to mid 20s where cars were blowing up with smoke and fire effects and there was lot of fighting onscreen.
I played the Rock and Hard place mission where you come down the road after the fight in the dense forest region. And you face more enemies in the open region and I could see similar fps around early 30s dropping sometimes to mid to high 20s . I seriously didn't feel that Rock and Hard place was far more demanding than the fight in the parking garage in operation swordbreaker. I can call it at best case similar.
I appreciate your effort. Very few will go out and actually back up their assertions with their own tests. Kudos!
If you look at the 4X MSAA fraps graph HD 7970 (950 Mhz) and GTX 680 they tail each other very closely except the last 20% where the GTX 680 is ahead. Also to my observation GTX 680 is more spiky (indicative of Turbo padding the average fps) than Radeon HD 7970.
That may very well be but the Boost technology is a feature so regardless of it "padding: the average, it is still doing its job. However, I have noticed in the vast majority of games that it won't jump around all that much (at most 5%) within a game.
It would help if you include a fraps graph of the tests as atleast as a downloadable zip file, if you can't clutter up your webpages with those graph charts.
I'll look into doing that in the next launch review.
Personally, I think that the HD 7970 is still a great card and has potential. It is based on an architecture with which AMD is learning the same hard lessons as NVIDIA did with Fermi. However, I think we will all agree with the fact that its architecture isn't up to the challenge of running with NVIDIA right now. It needs a revision that cuts back but doesn't eliminate its pointless (for the consumer market), power hogging GPGPU abilities and then AMD may have a good chance to recapture people's business.
