Old May 8, 2012, 03:52 PM
Default What's wrong? fixed
I had a working set of 6850/6870xfired. Now I took the 6850 out and put another 6870 in to xfire 2x 6870s. I have the new 6870 in the top slot so when I disable xfire it still works and it still makes these pics, what is it in the pics? Is the card just broken?
Thanks.
Ps, it also makes red lines.
Gaming FX 8350 4.4GHZ / Tuniq Tower 120/ MSI GTX 1070 Armor / G Skill 32GB / S12D 850w/ GA 990FXA-UD3 /SSD 240GB , WD1TB FALS, 3TB Toshiba / Dell IPS 1920x1080/ Win 10 64
Daily Use x4 965BE 3.4GHZ/GA 970 Gaming/ Rx 580 8GB /EA750w/4x4GB ram/Win 10 64 and 24TB of hdds
Old May 8, 2012, 05:17 PM
Adzsask's Avatar
Uninstall and reinstall drivers first thing to try.
Old May 8, 2012, 05:33 PM
What I was seeing on my end was bright green pixels all over is that in the pics, maybe my monitor is doing wierd things?
Old May 8, 2012, 05:56 PM
Bond007's Avatar
What is wrong with the pictures?
EDIT: if its on your monitor and not in the saved screen shots could be loose cable connection/ bad cable/ bad output (try attaching to a different output on the GPU).
Old May 8, 2012, 06:48 PM
Turns out it is a bad dvi port on the card so I used the lower port and it's all good again no dots or red lines.
Thank you 007.
Old May 9, 2012, 03:40 PM
Bond007's Avatar
Thank you 007.
No worries.
