Old May 4, 2012, 05:10 PM
Arinoth's Avatar
Yes I know, however I unplugged the mobo power connector too.
Here I am: here I remain
Old May 4, 2012, 05:39 PM
Dzzope's Avatar
Have you tried it with a single monitor on each DVI port? if it happens with 1 monitor and not the other then I'd suggest you get your monitor checked out..
If it happens with both.. well, calling galaxy support might be an option.
Old May 5, 2012, 05:22 AM
Bond007's Avatar
Does it do this if there are no monitors plugged in?
Old May 5, 2012, 06:58 AM
Arinoth's Avatar
So... it turns out that it's the first DVI port on my Samsung SA850 monitor that's doing this. Plugged into the second dvi port on it and into the primary of the card and it now longer is powering the fans on the system. So I'm guessing something went wonky with my first DVI port on my monitor eh?
Old May 5, 2012, 10:37 AM
Dzzope's Avatar
RMA it.. :)
Old May 5, 2012, 10:58 AM
Adzsask's Avatar
I would for sure RMA that monitor, can't be good when it is supplying extra power to your motherboard.
Old May 5, 2012, 11:25 AM
Dzzope's Avatar
Is that one of the 27" pls panels?
A bit jealous if it is..
Old May 5, 2012, 02:36 PM
Arinoth's Avatar
Yes it is Dzzope
  #19 (permalink)
Old May 5, 2012, 02:55 PM
NyteOwl's Avatar
I'd be tempted to RMA both the monitor and the card. The monitor shouldn't be back-feeding voltage to the video card, and the video card shouldn't be passing it along to the system bus.
Obsolescence is just a lack of imagination.
  #20 (permalink)
Old May 5, 2012, 06:45 PM
Bond007's Avatar
Sounds kind of crazy. Atleast you were able to trouble shoot and bypass the root problem.
How do i know if my "Drive Controller" is running in "AHCI mode"? Teo3201 Storage 2 October 8, 2011 09:54 PM
strange "all closed ports" problem CTA Troubleshooting 0 March 26, 2011 11:42 PM
BIG heat problem with "good" cooler kendallcschm Video Cards 12 September 11, 2010 10:36 AM
Strange "Copy Protection" problem Bullterrier Gaming 6 December 9, 2009 05:31 AM
Is "tearing" a result of a videocard or RAM problem? Gameplaywarrior Troubleshooting 16 October 20, 2008 04:30 PM
