First off, what's the processor that comp has? I thought FRAPS was fairly CPU dependent, and the only requirement for the GPU is that it at least plays the games well enough.
Second, I personally suggest not using FRAPS. Personally I'd go with Dxtory (
Dxtory.com | Home). The Engrish may take a bit to get used to, and it definitely is a bit more of a process to set up than FRAPS, but jesus is it ever nice. Recording and livestreaming 60FPS at 1080p with almost 0% performance penalty aside from the fact that my harddrive couldn't keep up, man was that nice.
Edit: Point 2.5: FRAPS can't make a file over 4GB in size. If you're recording at 1080p for any significant amount of time, you are going to end up with a boatload of 3.98GB files using FRAPS' "custom" codec, whereas Dxtory, you get one single file encoded with the codec of your choice right off the bat.
Third, do you have any real preference if it's AMD(always ATI in my heart) or NVIDIA? Because with the Geforce 670 coming soon, it might be best to hold out for that, see how it compares to the 7870, and if it's the right price, pick that up.
Originally Posted by Adzsask Soon as you said rendering, have to recommend an nvidia card,570/580 are lowering in price, lots of cheaper used ones available right now, maybe even an EVGA GTX480 on for $200 new right now. |
^ This right here.
