Old May 1, 2012, 04:14 AM
Dzzope's Avatar
Try bake, if not get the 570 / 480..
that or wait a month and HOPEFULLY there will be the 6xx mid range cards out which if nout else will drive the prices of your current options down even further.
But a month is a long time to go without a GPU.
Old May 1, 2012, 12:30 PM
Finally got chance to have a look inside my PC today and I think I found the problem. I have a fan on my side panel and one of the two wires came loose from connector that was attached to the fan header on the motherboard and was lying directly on top of the PCB :/
Would baking solve that?
Old May 1, 2012, 12:50 PM
Dzzope's Avatar
Try running it without the extra wire?
Old May 1, 2012, 12:57 PM
I don't think you quite get what I'm saying. Hopefullly my paint skills will help explain.
One of the two cables from the case fan nearby was lying on top of the video card PCB. I'm guessing it fell out while my computer was on thus causing it to short or out or something which is the cause of my problems.
Old May 1, 2012, 03:09 PM
BigPhatPaulie's Avatar
Well if it did major damage all you need to tell is to take a sniff.... if it smells like burnt electronics then thats your answer.... or you might have gotten lucky and the short didnt fry anything (unlikely though) :/ hope that helped
Old May 1, 2012, 03:23 PM
No burnt electronic smell which is good and Windows still works, just lots of artifacts on the screen. Got nothing to lose so just baked it to see if that helps. If it doesn't looks like I'll be waiting for the 660 Ti.
Old May 1, 2012, 03:46 PM
damaged v-card
no baking gonna fix it
try to find the spot it shorted to fix
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old May 1, 2012, 09:56 PM
EmptyMellon's Avatar
Have a good look at the back of the video card PCB, if a circuit was "blown", then you might see a break in one of the PCB circuits/wires.
"All animals are equal, but some animals are more equal than others." - G. Orwell, Animal Farm
Intel HD Graphics with Graphics Card MoUnit CPU's and Motherboards 4 August 6, 2011 03:54 PM
Need a graphics card kanadien Video Cards 16 April 14, 2011 04:37 PM
AMD Extends Graphics Performance Lead, Launches World's Fastest Graphics Card? Again! FiXT Press Releases & Tech News 2 March 8, 2011 03:32 PM
Best graphics card for ~100$ Bubbzilla Video Cards 8 September 6, 2010 09:55 AM
