Old April 27, 2012, 03:08 PM
Wink Asus Gtx 550 Ti Heat and smart doctor Help.
Hi.
My Asus GTX 550 Ti become about 65-80 C when i playing medium and high resolution games.
And it also make a small relly low sound like (try to explain so good as i can in words) "diiiit, diit diiiit, every 5/10 sec.", that was the sound i heard every time the card become warmer then about 75C. So could that be dangers or what? My PSU is from Seasonic with 620Watt and 80+ Bronze Certified, so i don't think it is my PSU.
I would like to know if this is decrease the lifetime of this graphic card?
On the Nvidia website they say it can handle up to 100C, but i have heard about some people there say,
a Graphic Card will have short life timer if it reaches about 80C, but i don't know what i shall think when the
website say it can do up to 100C.
I wondered about why Asus not list the Smart Doctor Utility on their GTX 550 Ti Cards.
I try to find drivers on some of their other Graphic Cards like GTX 560 Ti, GTX 570 etc. and they have all list the smart doctor utility, so is it because the Smart Doctor Utility dosen't work properly on Asus GTX 550 Ti? But the Smart Doctor Utility was on the Driver CD that followed with the Graphic Card, but now on their website.
And i just want to make sure that i can use that smart doctor utility with the GTX 550 Ti.
I have tried the Utility for a while, but it just felt like the utility got the GPU more heat, but anyway it could also just be me there have done something wrong in the utility. But if some of you have tried the Utility on the Card then please tell what you have experienced by using Smart Doctor on Asus GTX 550 Ti.
Thanks for your patience.
Old April 27, 2012, 03:35 PM
dandelioneater's Avatar
I don't think the sound you described could be ''coil whine". You should maybe pull out the card and inspect the fan for dust or any debris that may be rubbing. Assuming there isn't any dirt or broken fanblades you can then
use msi afterburner to turn up the speed of the fan. You can create a custom fan profile too. This will make te card run cooler.
You may also change the thermal compound on the gpu chip. Only do it if you know what you are doing.
Tags
asus gtx 550 ti , heat sink , smart doctor , smartdoctor
[FS] AM2 heat sink fan + back plate bracket (Asus OEM parts) + ethernet, SATA cable Sui Buy/Sell & Trade 17 September 5, 2012 09:07 PM
Need some help about a doctor Blu Off Topic 17 May 6, 2011 10:13 AM
ASUS Copper Heat pipes On GPU ( AMEinfo.com) ZZLEE Reviews & Articles from the Web 5 January 31, 2011 12:35 PM
[WTB] asus P5Q-deluxe mosfet heat sync. kyle_L Buy/Sell & Trade 2 July 13, 2009 10:24 AM
SMART error tom.mullie Storage 3 April 28, 2008 06:20 AM
