Old April 27, 2012, 06:58 AM
Default which card would you recommend?
Video cards are on sale. I plan to upgrade my ATI HD4850 (been procrastinating on this for a while). I mainly use it for photo editing, some games (my HD4850 gives me artifacts when playing online games and Mini-Ninja, I do not need high frame rate or max res). I am using Dell 2405 monitor which is 1900x1200 resolution.
There are these cards that come into my price range of about $200:
1. XFX Radeon HD 6950 800MHZ 2GB $210 (after rebate)
XFX Radeon HD 6950 800MHZ 2GB 5.0GHZ DDR5 2xDVI HDMI 2x Mini DisplayPort Fansink PCI-E Video Card - XFX - HD695XCDFC
2GB of vram. Is it of any use to me?
2. Gigabyte Radeon HD 6870 Windforce 915MHZ 1GB ($150 after rebate)
Gigabyte Radeon HD 6870 Windforce 915MHZ 1GB 4.2GHZ GDDR5 2xDVI HDMI Display Port PCI-E Video Card - Gigabyte - GV-R687OC-1GD
3. Galaxy 56NGH6HS4IXZ GeForce GTX 560 Ti Video Card 1GB ($175 after rebate)
Buy the Galaxy GeForce GTX 560 Ti 1GB GDDR5 PCIe 2.0 at TigerDirect.ca
4. EVGA GeForce GTX 570 HD Fermi 732MHZ 1280MB ($250 after rebate)
EVGA GeForce GTX 570 HD Fermi 732MHZ 1280MB GDDR5 2XDVI HDMI DisplayPort PCI-E Video Card - eVGA - 012-P3-1571-KR
5. ZOTAC ZT-50313-10M GeForce GTX 560 Ti - 448 Cores (Fermi) 1280MB ($270)
Newegg.ca - ZOTAC ZT-50313-10M GeForce GTX 560 Ti - 448 Cores (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
Choice 1-3, which one is better for my needs ?
Choice 4-5, which one is better ?
Thanks.
Old April 27, 2012, 07:19 AM
2 is better for your needs, but considering the prices I'd get 3.
4 is the better card.
Old April 27, 2012, 07:23 AM
SKYMTL's Avatar
HardwareCanuck Review Editor
None of the above. Wait about a month and you'll see MANY more options at those price points.
Old April 27, 2012, 07:39 AM
Thanks. I have waited this long, I'll wait some more.
Old April 27, 2012, 11:47 AM
Yea, the 6xx lineup should fill out allot in the coming weeks.. the new 660ti (or whatever they will call it) would be my option for a go-to card for your res... if you want a bit more power and have the funds then the new version of the 570 would be second..
Old May 7, 2012, 02:10 AM
Angela Byron's Avatar
I would suggest you to get number 4, it is the better for your needs.
Video Card Budget? Which one do you recommend? DSi Video Cards 10 February 14, 2012 12:52 PM
Recommend me a Workstation Card. Dr_BenD_over Video Cards 13 March 10, 2010 07:24 AM
Recommend me an LCD tv! Eldonko Off Topic 24 November 10, 2008 08:20 PM
what do you recommend jay51 Cases 8 July 2, 2008 03:00 PM
which CPU do you recommend? vblanche CPU's and Motherboards 23 September 15, 2007 09:34 AM
