Old April 13, 2012, 12:17 PM
botat29's Avatar
Default Video Card for 3 monitors
Hi, I need a GPU for my i7-2600k ( can use the iGPU on this motherboard) I'm thinking to get 2 GPU since I have 3 DVI monitors. I need the one who will take less power and produce less heat and capable to do the work. So what do you think will fit my needs ?
I use it for :
Photoshop Element ( very basic stuff for my website)
Web easy
Corel Draw 9
Office
I have 1 1920 x 1200 monitor and 2 1620 x 1050 monitor
Old April 13, 2012, 12:44 PM
supaflyx3's Avatar
A single GTX680, you can run 3 displays off of it.
Old April 13, 2012, 12:59 PM
botat29's Avatar
a GTX680 ? I'm not playing with this PC.
Old April 13, 2012, 01:02 PM
Keywork's Avatar
A couple of lower end Nvidia cards, or to simplify, a single ATI card since they have Eyefinity. I would probably go for the latter.
Friends don't let friends use onboard video.
Old April 13, 2012, 01:37 PM
Mena's Avatar
The Radeon 7970 can also do 3 monitor setup. You will need adapters though.
Team Red FTW. LOL!
I am watching you.
For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.
When a ladder was stolen from a store the manager said that further steps would be taken
Old April 13, 2012, 02:27 PM
newer AMD7xxx series cards i believe can run eyefinity over diffrent resolutioned monitors. So since its mainly office apps I'd sugest a Radeon 7750 if not 7770 card.
Old April 13, 2012, 02:45 PM
great_big_abyss's Avatar
Your purpose is just to run 3 monitors for desktop applications, and not for gaming?
In that case, most previous generation AMD cards will do the trick.
ASUS 6770
It comes boxed with an HDMI to DVI connector, so all you'll need to get is a VGA to DVI adaptor (they're dirt cheap) and you'll be set to run 3 DVI monitors.
Old April 13, 2012, 02:51 PM
Mena's Avatar
Originally Posted by terrybear View Post
newer AMD7xxx series cards i believe can run eyefinity over different resolution-ed monitors. So since its mainly office apps I'd suggest a Radeon 7750 if not 7770 card.
Ah yes....forgot about those. That would do the job for sure.
I am watching you.
Old April 13, 2012, 02:54 PM
botat29's Avatar
Originally Posted by great_big_abyss View Post
ASUS 6770
this one look nice, I don't really need the VGA to DVI, my third monitor as a VGA connector and I use it only for "Remote Desktop Connection Manager"
Old April 13, 2012, 02:55 PM
Mena's Avatar
I think the 7000 series also has better power management and lower heat. You may want to factor those in. The 7770 looks to be your best bet.
XFX Radeon HD 7770 Double D 1GHz 1GB 4.5GHZ GDDR5 DVI-DL HDMI Minidp PCI-E Video Card - XFX - FX777AZDF4
Here is one from the best of the Radeon makers....XFX.
I am watching you.
Advice on new Monitors+vid card kretzm New Builds 8 June 22, 2011 08:16 PM
Monitors for video wall magictorch Display Units 7 October 19, 2009 05:38 PM
2 Video Cards with 3 Monitors techadventures Video Cards 0 March 30, 2009 02:11 PM
Triple Monitors on one video card CrazyScott Video Cards 5 March 27, 2009 05:16 AM
WTB: Video Card/Sound Card/Hard drive - Look here if u gotz some ! Flintblade Buy/Sell & Trade 4 December 4, 2008 10:27 PM
