Old April 17, 2012, 09:34 AM
Killswitch's Avatar
Originally Posted by Slik View Post
My wife has a 730x,and the 580's are going into her rig. Right now,she has two GTX 480's,so they will be for sale soon.
If she's getting both 580's for sure...... then you had better upgrade that 22" monitor she's using to at least a 27". It would be such a waste of power and tech not too.
Old April 17, 2012, 11:42 AM
Slik's Avatar
My wife knows "overkill",and must have it all. Same as you and I. Overkill is good. I too think she should get a bigger monitor. After all,that's part of what overkill is all about. I think she is ready to get a 24 inch from Dell. It's a start in the right direction. Look how long it took ME to "catch on". I no longer buy pre-built PC's. And the thanks go to you Killswitch. You got me started.
EVGA DG 87 -i7 5930k @ 4.4ghz. Liquid cooled-4x4gb G Skill Trident X DDR3@ 2400mhz- EVGA x 2 1080 Ti Black SLI - Soundblaster X7 Sound Card- LG 34" Monitor-ATH AG1X Headphones-Butt Kicker Gamer-TrackIR 5
Old April 18, 2012, 02:24 AM
elmorejohn46's Avatar
The GTX-680 is a good card.I was surprise to see it so fast since nvidia said they would not start with there top-end cards first.I can only imangine how fast the top version of this card will be.I wish I had the money to get one but as long as my cards will play my games at a reasoable speeds I will keep them.I agree if you are running two GTX 580's in SLI then you want a monitor bigger then 22" .all the 22" monitors I have seen top out at 1920x1080.A single GTX 580 would be plenty for that .I would go with a 30" if I had the money .But I don't think games look to bad on a HDTV.I run mine on my LG 46" HDTV and love it althogh 1920 x 1080 is the highest its goes,but I can crank up the effects to max.But I would go with a 60" HDTV with 120hz and 2.4ms responise time over a 30" monitor that cost around the same but it does have a 2560x1600 resolution.
Intel-i7-3820+Corsair H-100+Gigabyte X79-UD5+16g G.Skill 1666DDR3+256g Crucial-SSD+1-3TB Seagate+2-1TB-Samsung+1-640g- WesternDigtal+SLI-ASUS DIRECT CU II GTX-670+LG-12x Blurner+Logtech G9x-mouse+G-110-keyboard+Driving Force GT Wheel+Pioneer VSX-1020K+Polk Audio Speakers+LG-50"Plasma PM6700+Antec-P280+XFX 850w PRO Semi-Modular
EVGA GeForce GTX 580 3GB Review Comment Thread SKYMTL Video Cards 30 June 28, 2011 03:29 PM
EVGA Geforce GTX 570 Superclocked Review Comment Thread SKYMTL Video Cards 18 March 6, 2011 12:57 PM
EVGA GeForce GTX 470 Superclocked+ Review Comment Thread SKYMTL Video Cards 8 June 25, 2010 11:11 AM
EVGA GeForce GTX 260 Core 216 Review Comment Thread SKYMTL Video Cards 33 September 26, 2008 10:51 AM
EVGA GeForce GTX 280 Review Comment Thread SKYMTL Video Cards 105 July 31, 2008 04:42 PM
