Old March 27, 2008, 02:56 PM
Default Ati Crossfire compatibility
Hello everyone,
I have a quick question:
I bought 2 MSI Radeon HD 2600XT 512MB 128bit GDDR3 PCI Express x16 HDMI HDCP & CrossFire, after after that I found on ATI Web page a Chart of Models you could put together and have Crossfire compatibility.
with mine HD2600XT as master it was showing a HD2600PRO as slave, but there was no case showing HD2600XT with another HD2600XT.
Is anybody knows that installing my 2 Graphics card I will get the performance Crossfire should deliver?
I try to get an answer from AMD/ATI Support but the only answer they gave me is MSI HD 2600XT is not officially certified by AMD/ATI as Crossfire, evenso the Spec sheet of this MSI card mentions it is.
Thks in advance for your answer.
ASUS P5K-E WIFI AP 775 /BIOS: V1012 / INTEL Core 2 Quad Q6600 2.40GHz 8MB L2 LGA 775 / 8 gb = OCZ Vista DDR2-800 CL 5-6-6-18 Dual Cha./ 2 : MSI Radeon HD 2600XT 512MB 128bit GDDR3 PCI.E x16 CrossFire / Maxtor 160GB SATA 3.0GB / W.D. Caviar SE16 500GB 7200 RPM 16MB Cache SATA 3.0Gb /LiteOn DVD Writer 20x L.Scribe Sata / Raidmax Ninja ATXN819WBP / Thermaltake Toughpower 750W / Win XP PRO Sp2 on HD1 / Vista Home Pre 64 bits Sp1 on HD2 / Samsung 226WB DVI / Perfect Choice KeyB&Mouse USB W-less /
Old March 27, 2008, 05:04 PM
vdf22's Avatar
I don't see why not. They both support CF so they'll both work.
Old March 27, 2008, 05:13 PM
Thks for this confirmation VDF22
Old March 28, 2008, 10:29 AM
lcdguy's Avatar
now i could be wrong but i thought some of the ati cards needed only one master card and one slave. But if it's anything like my hd3850's crossfire which uses an interntal bridge instead of an external cable than it should be fine.
Old March 28, 2008, 11:11 AM
CMetaphor's Avatar
Quadfather
I think that (master slave setup) was only the case long ago during the days of the x800 and the like. I seem to remember that you HAD to have one "Crossfire" card as the master and one "Crossfire ready" card as the slave.... no longer though! Crossfire even allows for just about Any two newer ATI cards to be put together. Woohoo!
Old March 28, 2008, 11:21 AM
Yes the HD 2600XT also use dual Internal Bridge, I say dual because when I plugged just one bridge the Crossfire option is not active in Catalyst.
Is there a way I can check if performance gets greater when I put the option crossfire? And could you confirm that is not yet compatible with Windows XP Sp2
Thks
Old March 28, 2008, 11:22 AM
Tks for the good news!
Old March 28, 2008, 06:07 PM
vdf22's Avatar
Yup. There were special Crossfire cards that had to be used to enable Crossfire. Those days are past.
