Old March 25, 2012, 12:50 PM
Default Multi-Monitor Performance Decreases
TL;DR - What are the numbers (fps drops, percentage performance drops) in regards to adding a monitor to a video card? Not gaming on all of them, but just having multiple monitors running when it comes to gaming performance. All resolutions would be >= 1920x1080.
Hello,
I've been trying to get a better grasp lately on how monitors affect performance from a numbers perspective. I game on one monitor and have no plans of changing that until the prices of bezel-less triple monitor setups drop, however I do run multiple monitors.
What kind of gaming performance decreases (in terms of numbers; percentages, fps) does adding a monitor to a video card have? Currently I am running 3 monitors with two 6850's, but I am likely going to be dropping one of the 6850's for a 7000 series card. I can't decide whether I need to get a 79xx or if a 78xx will suffice. In terms of performance, the benches I see show me a 7850 would play games at full with an acceptable frame rate at 1920x1080 (30-60FPS), but I feel like I need to get a 7950 if I am going to eventually have 4 monitors running off the card. My interest is in: how does that change when I add more monitors even if they aren't being used to play on?
I'm currently prospecting 4 more monitors into my setup for a total of 7. 3 on a 6850 and then 4 on a 7000 series card. Any thoughts or opinions would be greatly appreciated!
Thanks.
Old March 25, 2012, 12:59 PM
Arinoth's Avatar
Unless you are gaming on those monitors, it doesn't really adversely effect your frame rates for your game seeing as the card is rendering for the 1920 x 1080 resolution. Any extra/extended monitors are just there taking up little to know processing and video ram power.
Only when you game across the 3 monitors do the cards take a performance hit.
Here I am: here I remain
Old March 25, 2012, 01:26 PM
Thanks for the quick reply! So you think I can save some money and get a 78xx, run my 7+ monitors on it (and a 6850) and still get my 30-60FPS on ultra settings BF3 1920x1080? My wallet would love this option. ;) Do you think my route for this makes sense for adding more monitors?
Old March 25, 2012, 01:36 PM
Mena's Avatar
I am watching you.
For me, insanity is super sanity. The normal is psychotic. Normal means lack of imagination, lack of creativity.
When a ladder was stolen from a store the manager said that further steps would be taken
Old March 25, 2012, 02:26 PM
Originally Posted by Mena View Post
What can I say? I like my screen real estate and I like being able to have lots of information at my fingertips without have to close my game! :P Once they release a cost-effective bezel-less triple monitor setup I will be up to 10 monitors. :D
Anyone else have any input/numbers on how performance is impacted by adding monitors?
Old March 25, 2012, 02:34 PM
Bond007's Avatar
You can't run a 78xx and 6850 is crossfire (has to be the same generation).
Old March 25, 2012, 02:35 PM
There isn't because it doesn't.
There is no impact at all when you run multiple monitors even if one is dedicated as a gaming monitor.
Monitors that are just at the desktop require almost zilch for gpu processing.
Old March 25, 2012, 02:45 PM
I never said I was going to crossfire them, did I? Well aware how crossfire works. ;) You definitely CAN run two GPU's in one rig which is what I intend to do.
Thanks so much!
One Big tv or multi monitor fishingfanatic Display Units 5 November 29, 2011 11:25 PM
Multi Monitor Span & Clone enaberif Video Cards 2 May 3, 2011 05:38 PM
Multi-Monitor Gaming Arinoth Display Units 12 November 30, 2010 11:09 AM
Crossfire Multi-monitor setup? nzorov Video Cards 4 April 16, 2010 08:33 AM
New Nvidia Drivers / SLI Multi Monitor + SLI on X58 - 180.48 probationer O/S's, Drivers & General Software 14 November 26, 2008 09:40 AM
