Old March 14, 2012, 06:51 AM
Default BF3 lag when zoomed in
with my 6950 CF and 12.2 I've started noticing that when I zoom in with a 4x scope, the game lags a little bit every 2-3 steps I take
if I just zoom in and look all around i.e. no walking, no lag at all
Its very very annoying, I've only noticed for the last few days which was around the time I installed 12.2, but I'm not sure.
Any other ideas, any have the same problem?
found this, same problem, zoom+starfing=lag
Zooming+strafe=lag - Forums - Battlelog / Battlefield 3
i7 2700k - 7950 3GB crossfire - 4GB 1866 CL8 - 1600p
Old March 14, 2012, 09:46 AM
dandelioneater's Avatar
Maybe try disabling xfire to see if that is causing the issue. It could be the new drivers as well.
Old March 14, 2012, 12:35 PM
I've no issue, but I'm not Xfiring.
Old March 14, 2012, 01:26 PM
Sounds like you have the jitters/microstutter
Edit: thought I'd elaborate when you scope in you see more of the map in greater detail using more vram pushing you over that 2gb threshhold. Of course driver issues are possible as well, thats what buying AMD gets you.
Old March 14, 2012, 04:31 PM
it's 12.2. I had to go from ultra down to high to get it back up to my smoothness preference.
Went away when i reinstalled 12.1.
12.2 also lowered my hash rate by 50 mh....
Old March 14, 2012, 05:19 PM
artistpavel's Avatar
I've been running 12.2 for a few days, suddenly the fps dropped form 50-60 to 25, I reinstalled the drivers and it went back to normal.
Old March 14, 2012, 06:28 PM
I haven't checked my fps, I'll do that next time if I remember
but it only seems to be when zoomed and strafing
tank zoom is fine, and I think 8x and 12x scopes are fine too
Old March 29, 2012, 05:59 PM
turn graphics to the lowest, does it still lag?
