Tri-Fire Setup Questions
Hello
I have recently unlocked my sapphire 6950 toxic to 1536 shaders (6970 level), and overclocked to 960 MHz core + 1450 MHz memory (5800 MHz effective) @ stock voltage.
The amount of performance I am getting really impressed me and I was wondering if a Tri-Fire configuration with 3 6950s will work out.
I cannot get more toxic editions (I have looked pretty hard), and I was wondering if there are going to be compatibility issues when using different cards.
Specifically, will I be able to use all the shaders on unlocked cards if I cannot get the other two 6950 to unlock?
Can I mix and match brands of 6950? Are there any reccommendations? Is my corsair ax850 able to run trifire? Is my x2 250 able to run trifire?
I plan on mining bitcoin and/or folding and playing bf3. My system specs are in my signature.
Thank you for your time.
