Originally Posted by FunkyJunky 512mb GT 8800 has 2x PCIx power connection slots. Do I use them both or is only one required? It's not in the book.......:rtfm:......small pam only had 6 pictures on it and did not cover power connections. Thanks! |
That card can use just 1; But if you want to overclock using the jumpers you can hook up both for extra power.
