Old March 5, 2012, 11:40 AM
taimoorali007's Avatar
Default Weird Sound while playing!
Hi guyz,
Never happened, but as i recently installed FiFA12 on my PC. no AA, high rendered, 1600x900 reso. I was playing that suddenly I noticed whenever i entered to new option, some variable "Dial-Tone like" sound was coming outta my Card! I know i should check HDD first but seriously, thats weird, I was carefully hearing that no sign of sound from my HDD it was definitely my GPU making that sound, and as it got higher, i closed the game!
Help me! First time facing this weird problem! :(
Note* Just happening with Fifa, playing Assassin's Creed Revelations+SKyrim, no issue with them
thanks!
Old March 5, 2012, 11:45 AM
Sounds like your hearing the infamous coil whine of the GPU?
Old March 5, 2012, 08:17 PM
idk, but wats that? My GPU is on Deathbed!!! :'(
Old March 5, 2012, 08:20 PM
Choke CAps? ryt??
Old March 5, 2012, 08:41 PM
Silent_Avenger's Avatar
It's probably just coil whine, run furmark and see if it make the noise again. If it makes the noise it just means the card is working a little harder. Nothing too serious my 4 year old 4890 has been making a coil whine noise ever since I got it and it hasn't died yet.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old March 5, 2012, 08:50 PM
If it's coil whine it's not necessarily on its deathbed, it's just operating at a particular frequency that's in resonance with the coils, causing vibration you can hear.
Old March 5, 2012, 09:38 PM
sigh* Thnx! And i ran futuremark test of 3D mark 06 to 11, no whining! not at all! just heard yesterday while playing fifa12 and i noticed, only fifa 12 was taking my card to higher temp as compare to other games, 65-70C! O.o
Thnx for the help!
Old March 5, 2012, 09:42 PM
Thnx for the help!
Those temps are nothing. 80-90 is getting warm.
Old March 5, 2012, 09:43 PM
And plz guyz, now tell me wat to do, just keep it using or I should take some precautionary measures?
Old March 5, 2012, 09:49 PM
Like enaberif said 80-90C is starting to get warm and your current temps are fine. Are you getting graphical artifacts? Is your game freezing up or lagging horribly? If not you're fine.
Weird sound in my WD Caviar Green 500Gb taimoorali007 Storage 9 February 12, 2012 11:58 PM
Weird sound biagio1661 New Builds 8 December 30, 2011 02:43 AM
What is she playing? Mark Off Topic 10 March 9, 2011 05:44 PM
Weird Speaker/On-Board Sound Problem... mitchelt Troubleshooting 1 August 25, 2009 06:13 PM
Anyone playing AoC? Eldonko Gaming 127 July 25, 2008 09:25 PM
