Old February 28, 2012, 08:44 AM
botat29's Avatar
Default Gpu for my Workstation ?
Iím looking for a new GPU for my workstation; I want to build a website, so I need to learn Photoshop and similar software use to make the graphics for my website. I may also make some small rendering and small 3d drawings to add some animation to my website. For now I have 2 monitors one is 1920x1200 and the other 1680 x 1050 and probably add a third one. I donít think I will use eyefinity. I want something that will not bottle neck, I have a Maximus IV Extreme Z as motherboard so I can use more than a GPU if need. My CPU is a 2600k, I will not play games on this computer , I was using 2 x 560 before, I sell one here, but I feel it was best suit for my purpose, So what do you think ?
Old February 28, 2012, 08:54 AM
great_big_abyss's Avatar
To be honest, you could probably get away with a Quadro FX580. No need to break the bank on a workstation build that will only be handling small 3D models.
Old February 28, 2012, 09:04 AM
botat29's Avatar
How this Quatro will compare to my GTX 560 ? I never use a real WS GPU , and yes not breaking the bank is a good option, lol
Old February 28, 2012, 10:51 AM
What about budget, is there a certain limit you want to stay within? Would pre-owned GPUs come into consideration?
Old February 28, 2012, 11:06 AM
botat29's Avatar
I will like to stay under $ 500 and I usally buy new stuff
Old February 28, 2012, 05:01 PM
botat29's Avatar
Someone can help me on this one ?
Old February 28, 2012, 06:13 PM
Nvidia Quadro - Wikipedia, the free encyclopedia
Assuming that Wiki article is correct, there are some feature that aren't available on the GeForce card even tho the guts are the same.
Quadro Spec PDF
http://www.nvidia.com/content/PDF/pr...er-revised.pdf
Geforce Spec HTML
Graphics Cards Buy Now
Old February 28, 2012, 07:00 PM
artistpavel's Avatar
Back in my day, one could flash a GeForce 8800GT with a Quadro bios and save thousands of dollars, check if people still do that with 560s.
Old February 28, 2012, 08:20 PM
People are modding gtx480s into Tesla C2050s.
GTX480 to C2050 hack or unlocking TCC-mode on GeForce - NVIDIA Forums
Old February 28, 2012, 08:33 PM
botat29's Avatar
Thanks guy but I'm looking for something I can purchase not mod
New Workstation build kpamir New Builds 4 March 5, 2011 07:50 PM
CAD Workstation: X3440 vs 760 vs 860 tzoutz New Builds 11 January 4, 2011 03:12 AM
New Virtualization workstation doup93 New Builds 11 October 12, 2010 11:22 AM
3D Workstation Paul Rogers CPU's and Motherboards 6 January 11, 2008 05:08 PM
Workstation displat Amon Display Units 16 August 17, 2007 07:19 AM
