Old February 24, 2012, 01:33 PM
musicman's Avatar
Default 7970 or 7950?
Ok so I'm going to be upgrading my GPU in the next couple days and I'm not sure what to get. I'm indecided between a 7970 and 7950. I like the performance of the 7970s but the price of the 7950s. So my question is, which will give more bang for my buck?
Old February 24, 2012, 01:46 PM
dandelioneater's Avatar
7950 will be better in the performance/$ category and You can probably overclock the 7950 to rival the performance of the 7970.
I guess the question to ask yourself: "Is it worth an extra ~125-150 dollars for a ~10-15% increase in performance?.
Old February 24, 2012, 01:47 PM
great_big_abyss's Avatar
The 7950 technically gives you more 'bang for your buck'. It's 90% of the performance at 80% of the price. But really, the difference is marginal. If you can afford it, go with the 7970. If you can only afford the 7950, go that route instead.
Old February 24, 2012, 04:05 PM
A good 7950 such as the Sapphire ones, or XFX ones, can overclock like crazy easily besting a 7970, though, 7970 can overclock even moreso, so it really depends on your $. I owuld just go a 7950, find the ones that have on average a really nice overclock, and go from there. the $/performance especially taking into account the overclocking headroom is just better with a 7950, the best of them will get within just a couple % of a very overclocked 7970 as well :)
Course, if you wait a few days, the 7890/7870/7850 will also be out,, and they should be the best $/performance with some very significant gains from overclocking as well.
Old February 24, 2012, 06:11 PM
Bond007's Avatar
Better performance/$ is 7950 hands down. The 7970 is just better performance. Unless you have a need for that extra bit of FPS, or have some extra disposable income, then the 7950 is the way to go.
Old February 25, 2012, 05:29 AM
with the same clocks, its about a 3% difference in performance.
Overclocking a 7950 then makes a lot of sense.
a 7970 tends to OC higher, around 100mhz.
Normally in a game, you wont notice any difference between the cards.
Old February 25, 2012, 06:43 AM
I think if your monitor resolution is lower than 1080P, then neither. If it is 1080P and the refresh rate is 60hz, go for the 7950. If it's 120hz, then HD 7970, or even 7950 CF.
Basically..
Old February 25, 2012, 08:47 PM
Hardly what I'd call a POS...
Old February 25, 2012, 09:23 PM
it depends on your resolution i guess. i personally would take the hd7970 if i had the money simple because i have a need to have whats best... ><
Old February 26, 2012, 09:44 AM
I thought about this while I was waiting to get a new 7970 since my first one was defective and hard to find (non reference cooling). I stuck with the 7970 because I figure for the long run, it will do better at the res I'm playing at (2560x1440).
I even went and got another 7970, so I'll likely be going CFx after I swap this new card (too much coil whine).
AMD HD 7950 Reviews Comment Thread SKYMTL Video Cards 72 January 13, 2014 12:03 PM
i7 2600k with gtx 580 or 7950 3GB My2cents Video Cards 7 February 14, 2012 07:25 AM
Gigabyte 7950 $479.99 foredown Video Cards 4 January 22, 2012 06:56 PM
7950 GT for 129$ ebdoradz Video Cards 1 March 8, 2008 03:00 PM
