Yep, if you want to do multi-monitor gaming, I only suggest triple monitor setups and you'll want dual GPUs (seriously, other than the 7970, there is no single GPU that could push reasonable quality & fps across 3x 1080p monitors).
I can't give great advice on the rotating side monitors 90*, but I'm pretty happy with 3 monitors in landscape mode. It's just so immersive feeling to have everything off in your peripherals. Just remember than for eyefinity you basically need identical monitors, where surround is friendlier with mixing monitors (this may have changed since I last looked it up).
A lot of games do work, but then again, there are lots that don't work properly with multi gaming. From what I read, I get the feeling that nvidia/surround usually offers more/better support in games than ATI/eyefinity. For pushing 3x 1080p monitors, nothing less than dual 6950s or 570s imo. Unless you really don't care about playing on high settings or full resolution.
