-   -   MSI afterburner problem with fans on crossfire (http://www.hardwarecanucks.com/forum/video-cards/51877-msi-afterburner-problem-fans-crossfire.html)
TedShackley February 23, 2012 06:03 AM
I use a custom profile for both my 6950s, and it seems to work most of the time, but not always
But one thing is although when Win7 starts, MSIAB starts, it NEVER starts the cards on the custom profile, I always have to hit 'reset' in MSIAB and then the 'user define' button next to the fan control
So how to I have it start with my custom profile?
taimoorali007 February 23, 2012 06:34 AM
Did you mark on fan controller tab? becuz, whenever you set fan speed then uncheck it, it will set to default again!
TedShackley February 23, 2012 06:41 AM
in settings on the fan tab, "enable user defined ...fan control" is check marked
and on the general tab, both cards are synced, start with win7, and start minimized
Eluder February 23, 2012 10:57 AM
And most importantly, make sure you enable Apply Overclocking settings at startup.
This is something I found out cause I had the same issue when I had my 6950. That option is required for the custom fan profile to start on bootup.
TedShackley February 23, 2012 04:32 PM
thanks
and thats hard to spot, its not in settings, its in small print at the bottom of the main left panel
Eluder February 23, 2012 07:56 PM
Ya, definitely not the most intuitive design.
