Old February 20, 2012, 07:27 AM
Prolab's Avatar
Default OC (2) 6950 w/ 6970 bios
Well, i finally got my system all set up. ATM, im able to OC my 6950's up to 950 Mhz Core and 1450 Memory clock w/ 1.16 mV using Afterburner 2.1.0.
It pass Kombustor for 30+ mins and BF3 for 2+ hrs w/o any artifacts.
Im willing to OC them past 1GHz. Am i able to do it pass 1+ Ghz? Or is this the extent of my 6950's?
Gaming Rig:
-Swiffy 655 & 360 rad, 360 XSPC Rad, HK Supreme HF, EK D5 top rev.2, AMD BE 1100T OC to 4.07 ghz, 16 GB G.SKIL F3-12800CL9Q-16GBXL, Asus Crosshair V, (2) XFX 6950 w/ XPSC WB, Crucial M4 128GB & 120 GB Vertex 2 EXT, (4) 2 TB WD Green Drive, Corsair AX1200, Win 7 Pro 64-bit
Server Rig
-AMD Athlon II 245 stock, Asus Mobo, 2 GB DDR2 Kingston, WHS, 500 GB WD Black, (2) 2 TB WD Green, (2) 2 TB Seagate HD, (1) Samsung 2 TB F4, Fractal Design R3, Antec 650 watt PS
Old February 20, 2012, 07:40 AM
Every card is going to be different, but to hit a GHz you'd likely have to up the voltage, so as long as you have good cooling, you could give it a shot.
Old February 20, 2012, 09:26 AM
Adzsask's Avatar
I have overclocked a few, most did 950, but after 975 or so your going to need a better cooler to keep stable.(friends 6970's would go to 990 core, but after an hour or so of being under load would lock up, so 950 was all the stock cooling would allow.
Old February 20, 2012, 05:22 PM
Prolab's Avatar
I guess i failed to mention, they're both WC.
What do you guys use to OC past 975? Im only limited by AB up to 950.
Gaming Rig:
Server Rig
Old February 20, 2012, 07:07 PM
AB allows it, you just have to enable unofficial overclocking mode, or run msiafterburner.exe /xcl to which it will make a registry change to lift the CCC limits.
Old February 21, 2012, 11:27 PM
Prolab's Avatar
Ok, i just read the thread on how to enable OC mode.
Thanks!
Gaming Rig:
Server Rig
[WTB] matx AM3 board krajee Buy/Sell & Trade 16 April 11, 2012 01:52 AM
[FS] (2) Ref XFX 6950 w/ XSPC WB Prolab Buy/Sell & Trade 85 February 22, 2012 05:34 AM
Best 6950 to BIOS unlock to 6970 Apathetik Video Cards 7 December 6, 2011 08:55 PM
GTX 480 vs ref 6950(6970) cruisx Video Cards 9 October 20, 2011 01:33 PM
Sapphire Toxic 6950 2GB Question - Preloaded with HD 6970 Bios? Zak_M Video Cards 2 August 24, 2011 08:06 PM
