<~----> HD7970, overclocking past 1125MHz - Hardware Canucks
Old February 19, 2012, 12:37 PM
lowfat's Avatar
Default HD7970, overclocking past 1125MHz
The limit in Overdrive is 1125MHz. Limit in MSI Afterburner beta 12 is 1125MHz. TriXX won't overclock a single MHz since it gives me a ULPS error (even though the disable ULPS is checked).
Anyone know of a way to pass this limit?
Old February 19, 2012, 01:40 PM
msiafterburner.exe /xcl
That'll lift the CCC limits.
Old February 19, 2012, 02:05 PM
lowfat's Avatar
Application won't even launch if I add that.
Old February 19, 2012, 08:27 PM
Odd, works fine for me and that's how I OC my 7970.
Other option is to enable Unofficial Overclocking in the cfg file, but I believe that may not work with the latest AMD drivers as they've removed some .dll that allowed this 'backdoor'.
Old February 20, 2012, 08:25 AM
lowfat's Avatar
When I enable the unofficial overclocking in Afterburner, it removes all clock control.
Old February 29, 2012, 08:30 AM
Does CCC not test overclocks anymore? When I had my 4870 there was a feature that would automatically OC your card and test it's stability for you. I haven't OC'd my video card in years is there anything I should know or use to test?
Old February 29, 2012, 08:59 AM
The main thing to know is that you'll get little benefit out of it. So if you do it for fun, go for it. If you expect performance increase, dream on.
Old February 29, 2012, 10:50 AM
I was thinking that it would be fun to increase the FPS on my 7950 a bit to help with folding and gaming. From what I read in reviews it seems that most 7950's can OC to 7970 speeds.
Old February 29, 2012, 11:05 AM
You'll have to get a real OC tool to get to 7970 speeds though, and may have to up the voltage.
Old March 1, 2012, 06:16 AM
which tool would people recommend? I hear of many different ones such as MSI Afterburner and Sapphire Trixx. Is one better than the other?
HD7970 Waterblock scristi Water Cooling 11 February 11, 2012 03:45 PM
i7 920 can't get past 3.5Ghz fjanicki Overclocking, Tweaking and Benchmarking 6 November 2, 2010 02:46 PM
Blast from the past JD Overclocking, Tweaking and Benchmarking 10 May 15, 2009 07:36 PM
Pics from the past... Toronto122 Case Mods, Worklog & Gallery 42 May 2, 2009 10:17 AM
Overclocking past 3.0 Ghz and Gaming... Rausch Overclocking, Tweaking and Benchmarking 11 February 8, 2008 10:29 PM
