Old February 16, 2012, 11:33 AM
Soultribunal's Avatar
Originally Posted by NyteOwl View Post
Regarding your "degraded" power supply just a comment.
I always have to shake my heard when I hear such remarks. While components can degrade over time, it is by no means a given, or that equipemtn has to be discarded after some arbitrary period of time. There really is no "Best before" date for electronics. Most modern electronics usually either fail within the first thirty days or (under normal sue) last longer than their owner has use for them.
As to the computer power supply, I have the following machines (among others) in regular use here:
K6-2/350 built 1999
K6-2/500 built 2000
K6-III+/600 built 2002
386/40 built 1991
8088-8 built 1986
All are using the original parts they were built with - including power supplies. Some of them have seen month long periods of 24/7 (one was my BBS machine and one still runs a radio BBS system).
So, if your PSU is functioning well and has been offering no problems, and is of sufficient capacity, simply its age is not necessarily a reason to replace it.
JMHO and as with all such, YMMV :)
WHile it might not be a matter of degraded state, Old PSU's are much less efficent and comply to a completely different set of standards than are current. This will have a dramatic effect on something say like an SSD which tend to be a LOT more sensitive to 'dirty' power.
I am sure in all the systems you list if you popped an SSD in the mix you would kill it very fast.
So, given that his PSU is 6 years old. Replacing it is a must if he is going to make a current system. Doing anything else would just be foolish risk of brand new hardware. Something I would never suggest a member to do.
-ST
Old February 16, 2012, 04:06 PM
Thanks Nyte owl! Feel free to chime in on the config recommendations too!
Upgrading from a GTX 460. SLI? Wait for 7xxx? Looking for advice! Bentech Video Cards 8 February 14, 2012 04:35 PM
Upgrading from 9800gt, would appreciate any/all advice Navi Video Cards 13 February 3, 2012 02:15 PM
Upgrading to SB. Need some advice please. ern88 New Builds 17 March 18, 2011 05:53 AM
Upgrading forever Upgrading nerty New Builds 6 May 8, 2010 11:28 PM
Need some advice before upgrading my old ass computer Syrax Video Cards 28 April 7, 2010 05:24 PM
