Old February 13, 2012, 09:28 PM
Default Power color or Ati reference card.drivers question.
I'm planning on purchasing a power color 6950 2gb vortex II card soon and I was wondering where should I download the latest drivers? power color website or Amd Ati website? both? power color last updated their 6950 drivers in 2011.12.14 but ati updated their drivers in 2012.. so.. should I purchase an ati reference design card for their better drivers or does power color also supports ATI drivers?
so basically my question is:
are ATI drivers only for Ati reference cards?
if I do purchase a power color 6950 2GB should I download both ati drivers and power color drivers?
ati drivers:
ATI Radeon
power color drivers:
PowerColor Official Website - Graphics, Cases, Power Supply
note:
noob question here:
is PhysX an Nvidia only technology? ati cards does not come with PhysX features do they?
Old February 13, 2012, 10:13 PM
Use the AMD ATI drivers. In terms of driver support, it doesn't matter what brand/design you buy.
Old February 13, 2012, 10:20 PM
you sure? would appreciate opinion of others too :)
hey, thanks man.
Old February 14, 2012, 05:51 AM
Jebusman's Avatar
hey, thanks man.
He's dead on. Brand is irrelevant, they all use the same drivers. Just grab them from the AMD site.
Old February 14, 2012, 07:51 AM
ok thanks guys :)
unfortunately vortex II edition is sold out @_@ so I am now aiming for either a ASUS direct CU II 6950 2GB or club 3d 6950 2GB.
here's the problem..
on newegg the ASUS Direct CU II 6950 2GB only has openGL 4.0 while the latest is 4.1 and 4.2, how do I upgrade it's open GL version? does the latest AMD drivers automatically installed newer version of openGL?
or am I stuck with open GL 4.0 on the asus direct CU II 6950 2GB? basically my question is:
how do I update my Open GL version? can it be done by installing latest drivers from AMD site?
second question is..:
I'm aiming for the ASUS direct CU II 6950 2gb but I'll consider club 3d version too..club 3d is relatively new to me.. I haven't heard much of it until recently. is it any good??
Old February 14, 2012, 09:59 AM
guys? :D
Old February 14, 2012, 10:27 AM
dandelioneater's Avatar
what about a 7950?
Old February 14, 2012, 11:15 AM
can't buy a 7950 3GB now :(
Old February 14, 2012, 12:56 PM
why are people buying sapphire 7950 3GB OC edition? can't they overclock the 7950 3GB non OC edition themselves and save a couple of bucks?
Old February 14, 2012, 03:55 PM
NyteOwl's Avatar
The OC edition comes with the custom cooler (heat sink and dual fans). The non-OC model is the stock reference design (also currently offered by MSI and HIS) and while you can overclock it, it will not cool as well with the stock HSF assembly if you do overclock (nor will it be as quiet). Considering the price difference is only $20 (at NCIX) and considering the cost of an aftermarket cooler and fans, buying it already set up from the company seems a no brainer, considering it seems to work so well.
Obsolescence is just a lack of imagination.
[FS] Various Computer Components (Nothing right now) Asad_A203 Buy/Sell & Trade 18 June 8, 2012 08:02 AM
Price check please for a Power color 1G 5770 Your_friendly_gamer Price Check 2 September 4, 2011 03:46 PM
Whats the difference between a reference card and regular card? Swift Assassin Video Cards 5 March 7, 2011 04:53 PM
Asrock N68-S UCC with Power color HD5670 512 graphics card cl0ud CPU's and Motherboards 4 November 19, 2010 07:36 AM
