Old February 13, 2012, 01:43 PM
Default What size PSU do i need?
I have a ax850 watt PSU and i was wondering if it is big enough to power 2 7970?
My current system config:
Asus Rampage IV Extreme
AX850 Watt
Intel i7 3930k @ 4.25 GHz
16 Gigs of ram from G.Skill
GTX 590
I do not really want to change my video card. I am just wondering to make a cost estimate!
Thanks for your reply!
Old February 13, 2012, 02:24 PM
stoanee's Avatar
Well, looks like 2 x 7970 at load pulls 700+ watts. Personally I would bump up my psu wattage.
heatware
Old February 13, 2012, 03:48 PM
bigFOIG's Avatar
It'll work, I'll tell you that!
Old February 13, 2012, 04:00 PM
Alright! But will it work for more then 2 minutes lol? Like i mean will it actualy work with no risk?
Another theory/question i got is this: GeForce USUALLY i said USUALLY makes cards that are quieter and pull less power, do you think the 600 series will follow the same trend? Quieter and less power consumption??
Cause if that works out like that and the cards look pretty good, i might go and buy 2 GeForce cards! :P
Old February 13, 2012, 04:22 PM
dandelioneater's Avatar
Actually in the last few card generations, Geforce cards have been a bit more power hungry than their amd counterparts: example (gtx 480 vs 5870) But they performed a bit better too.
850W is fine for 2 high end geforce cards. If you are going to run the system at full load (folding) 24/7 then maybe a 1000W unit would be better, but 850 will be fine for regular use.
Old February 14, 2012, 05:56 AM
Bond007's Avatar
I would say you are good to go on the 850w.
The latest HWC review of an OC Gigabyte 7970 with an i7 920 @4.0ghz pulled 361w (that is the whole system). So even if that doubled with a second card (which it won't) you would still have a bit of headroom.
Old February 17, 2012, 02:55 PM
Alright!!!!! Thanks everyone!! But i got one more question!! What would be the performance upgrade if i would do it?
Old February 17, 2012, 03:11 PM
Adzsask's Avatar
Cleaner power= longer hardware life, if your pushing your PSU to 80%+ when loading it is going to have some ripple, most go overboard to keep load% down, and also keeps efficiency.
Old February 17, 2012, 07:22 PM
486's Avatar
486 486 is offline
Non-overclocked 7970 does not consume more than 200W. 2600 with 2x7970 will consume no more than 600W. Seasonic 650 will handle it with ease.
If you are pushing your PSU to 90%-100% of load, the lifepspan of PSU still going to be longer than its useful life (connector/specs wise).
Sure, if you have cheap PSU, even 1000W won't be enough.
Fractal Design R5 + Seasonic X-660 650W
Asus X299 TUF Mark 2 + Intel i7-7800X + G.Skill Ripjaws V 3200 8GB x 4
Samsung 950 Pro 512GB + Samsung 850 Pro 512GB + HGST 5400RPM 2TB
Evga GTX 1080 FTW 8GB + BenQ BL3201PH 4K 32"
what size psu jimmyb007 Power Supplies 6 January 3, 2012 10:22 AM
Help with fan size biagio1661 Air Cooling 5 October 25, 2011 02:07 PM
Gtx 275 vs gtx 570 size coalminer071 Video Cards 8 October 14, 2011 11:30 AM
Antec PSU size fit sankukai Power Supplies 9 March 2, 2011 11:36 PM
Rad Size homer98 Water Cooling 11 December 10, 2010 09:33 AM
