Originally Posted by Pedwar Okay so recently after playing BF3 I've noticed that the my 550Ti SLI is bottlenecking my AMD 8150 Bulldozer.. It caused the game to stutter a LOT until I turned the textures and shadows down, but atleast now I can play it. What's the best card I can buy, that won't bottleneck the CPU, and will also be reasonably priced (I'm only 16 so money is kinda a problem and I don't wanna waste any more on crappy hardware like the 550Ti and tbh the Bulldozer, should've bought a 2500k in the first place). So what's the best GPU I can buy, for cheap, and won't bottleneck? Or will I have to save up to avoid any kind of bottleneck? |
The 8150 isn't bottlenecking your 550ti. You can keep throwing better/more gpus at the 8150 and you'll always see an increase. The 8150 is very comparable to a 2500K for gaming (except it's more money and less good at lightly threaded apps!). Don't expect a miracle from the 2500k with a 550ti setup.
You should go for a good single card solution, what is your budget?
I would say that the increase from dual 550ti to a single 560ti shouldn't be a crazy amount of fps more, mabye say 10? 20?
I'm sad to say that i'd recommend at least a single 580 to run bf3 at competitive frame rates on ultra settings.
I mean, who wants to play FPS with antiailiasing off?
