  #21 (permalink)
Old March 13, 2012, 08:25 AM
bTx bTx is offline
Trial Member
cppl things......the most likley culprit here is your vram....run fraps or afterburner and watch it max right out!!!
2 thing..550 ti sli IS a 560 ti......
  #22 (permalink)
Old March 13, 2012, 08:49 AM
Try turning AA and SSAO/HBAO off...then see how it works.
Desktop: X3 710, 4GB DDR2 1066, MSI Cyclone GTX 460, Seasonic S12II 500W
Away from home light Gamer: Acer Aspire 15.6", A8-3500m, 4GB 1333
Internet/General Use: Lenovo B570 15.6", i3 2330m, 4gb 1066mhz
  #23 (permalink)
Old April 11, 2012, 10:02 PM
Trial Member
Your issue is VRAM usage i promise. I had 2 gtx 550ti's in SLI on a phenom 2 x4 955 BE oc'ed to 3.8ghz and if i tried to run ultra or msaa on it would play fine for say 5 min or so then boom lag the hell outa and almost lock up, gpu usage and cpu usage maxed. Now im running a fx 8120 and a gtx 560ti 2GB, my vram usage in BF 3 on ultra with 4xmsaa - 1.7 gb's so yea. You should have gotten 2 550ti's with 2 gigs of vram, cause in SLI you only run one cards vram while the others is just shadowed. A fx 8120 isnt gonna show you any noticeable bottelenecks. Especially not in bf 3 as it uses all 8 cores of a BD
What is Bulldozer?? KSiG CPU's and Motherboards 16 October 11, 2011 01:42 PM
Bulldozer delayed again? dma0991 Rumor Mill 39 September 29, 2011 02:49 PM
Bulldozer Ships Sam_Reynolds Press Releases & Tech News 2 September 7, 2011 05:52 PM
Bulldozer now available in China The Package Rumor Mill 7 June 2, 2011 05:35 PM
I7-980X or i7-960 or Bulldozer ivanlyf_2011 New Builds 11 January 2, 2011 10:06 PM
