Old February 5, 2012, 09:44 PM
486's Avatar
486 486 is offline
Default Weird noise
After installing 7970 I ran WEI test and PC emitted very weird noise, like metal thread going thru metal plate. Not very loud, but noticable. I play mostly BF3 and there is only GPU fan sound as expected.
I have read that many GPUs have coil noise when ran at very high FPS (500+). Can it be related?
My other theory that it is 5400 RPM hard drive spinning up and down (it may have produced that kind of noise), but it is my third drive. Does WEI tests all drives?
Any thoughts are welcome.
Fractal Design R5 + Seasonic X-660 650W
Asus X299 TUF Mark 2 + Intel i7-7800X + G.Skill Ripjaws V 3200 8GB x 4
Samsung 950 Pro 512GB + Samsung 850 Pro 512GB + HGST 5400RPM 2TB
Evga GTX 1080 FTW 8GB + BenQ BL3201PH 4K 32"
Old February 6, 2012, 12:02 AM
Silent_Avenger's Avatar
Coil whine is usually only evident when putting the gpu under load. So run furmark or unigine heaven or 3dmrk11 and see if you still get that noise. If you do it's most likely coming from the gpu.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old February 6, 2012, 02:14 PM
Soultribunal's Avatar
GPU or PSU for the most part.
Though I did have one board that gave some wierd whine too.
-ST
www.realhardwarereviews.com
Old February 6, 2012, 07:49 PM
486's Avatar
486 486 is offline
Default benchmarked
Tried 3d mark 11. Hardly any noise (can't notice). WEI, for some reason, brings out the worst :)
Old February 6, 2012, 08:05 PM
Run something else. WEI is useless as a benchmark program.
-ST
Old February 6, 2012, 09:12 PM
Run furmark and prime95 at the same time that should push your system to the limit and also see if your system is stable. See if the noise still happens then.
Corsair PSU Noise Astaroth Power Supplies 8 March 3, 2011 12:41 AM
Harddrive Is making a weird clicking noise andynerd Troubleshooting 3 November 11, 2010 08:23 PM
Need help with noise etc.. shadow of chaos Water Cooling 6 August 24, 2010 08:21 AM
120v outlet filter for noise, such a thing? (popping noise from speakers) On2wheels Troubleshooting 3 June 20, 2010 08:06 PM
Weird noise coming from GPU Kilauea Troubleshooting 8 September 30, 2009 05:27 AM
