<~----> Question for EVGA GTX 580 SSC - Hardware Canucks
Old February 4, 2012, 12:34 PM
Alpine's Avatar
Default Question for EVGA GTX 580 SSC
Hi guys, i have buy a Ecga GTX 580 SSC. I found it used for 350$ Not bad. The card still have the plastic protection on.
So, i just would likke to know if that normal that the card is reaching 82c while gaming ? IM pretty sure it is but i just want to be sure.
• ► › I7 3930K|Asus P9X79 WS|Evga GTX 690 Signature|Corsair Force 3 120GB|Corsair H1000|Corsair Dominator Platinium 16GB 2133Mhz|
Corsair AX1200|Corsair 600T SE|Corsair SP2500|Corsair Vengeance 2000
• ► › I7 2600K @ 4.9Ghz|P67A-UD4-B3|12G G.Skill 1600Mhz|Noctua NH-D14|OCZ Vertex 2 60GB|EVGA GTX 580 SSC|Corsair AX650|Lancool PC-K62|
Old February 4, 2012, 12:47 PM
Silent_Avenger's Avatar
Sounds slightly high you may want to manually set fan speeds using MSI Afterburner if you want better temps. As for will it kill your gpu or not, it probably won't affect it my 4890 runs at 80c a lot of the time and it's 4 years old.
Edit: Btw sweet deal on the card.
Main System //// Dedicated Folding PC 1 //// Dedicated Folding PC 2 //// Laptop
Youtube Channel: http://www.youtube.com/DarkDivinityPC
I fold for a cure. Team 213366 and 54196.
Old February 4, 2012, 12:58 PM
Soultribunal's Avatar
The SSC is second highest clocked from Factory stock. So you are talking about a high end card there, running right at its limit.
As suggested just set your own fan profile to be a bit more aggressive on the cooling, and remove that plastic. Bad idea to have it on there.
-ST
Old February 4, 2012, 01:22 PM
Alpine's Avatar
thanks guys. Proctection film is already off. Don't worrie about that.
Im gonna take a look at the fan profile with evga precision.
Old February 4, 2012, 03:12 PM
pellelu's Avatar
You could also use eVGA's Precision and OC Scanner to tune your fan.
Old February 4, 2012, 03:26 PM
flash to newer bios to unlock fan speed
GTX 500 Series Firmware Update + Fanspeed Unlockers
haven't seen mine hit 40c yet lol
maximus IV extreme @ 5.1 1.41v
evga e760 +920 4.8 water5.0+ on phase linx stable
gtx285 tri-sli
dfi ut-p35 lt
e8600@4.6 1.38v
too much ram
Old February 4, 2012, 04:13 PM
Alpine's Avatar
ohh... thanks Zsamz....
Old February 4, 2012, 04:25 PM
if your card doesn't hit 40+ while gaming then you're doing something wrong, or are being lied to.
Old February 4, 2012, 04:29 PM
Alpine's Avatar
maybe he's on water ?
Old February 4, 2012, 04:30 PM
then why would you need a fan profile for the card?
EVGA GTX 470 Question Kommie986 Video Cards 7 September 2, 2010 08:13 PM
Evga 295 - Question for gamers Stark.tD Video Cards 16 February 12, 2010 07:20 PM
EVGA GeForce GTX 295 question. Schnerf Video Cards 10 July 29, 2009 04:36 PM
EVGA step up question Realityshift Off Topic 9 April 25, 2009 11:15 AM
Question (EVGA 8800 GT SC) AnthraxAdrian Video Cards 12 April 21, 2008 05:37 AM
