  #21 (permalink)
Old February 5, 2012, 12:26 AM
Dwayne's Avatar
Originally Posted by rjbarker View Post
Sorry dude dont think any Aftermarket Air Cooler is worth it....please post pics of running Crysis2 DX11, FEAR3 DX11 or BF3 with Max Temps of what...?....52c.... I personally am going to call you on that one and say bullshvt, unless its with your GPU Fans spinning at 150% and who needs that noise n racket .....sorry man cant buy that one! Any decent Aftermarket Cooler you'llbe lucky to get a decrease of Max Load Temps of around 8c...so you were running 60c Max prior to installing your Aftermarker Cooler?...yeah right hahahaha!
Tri SLi 580's all stock with Fans running at 78% I saw Max Temps on middle Card of 74-78c..perfectly fine, likely around 70c with a single Card
The only problem with those Aftermarket Coolers is they dump the heat from the Card into the Case ...that sucks.....and they prohibit running SLi with a decent space between the Cards.
The 580's certainly dont need an Aftermarket Cooler(as compared to the 480's), as a Max Temp of 75-80c is perfectly fine for these Cards and there Stock Cooler is specifically designed to expel the heat out the back of the Case!If your going to install an Aftermaket Cooler on these Cards, may as well "do it right" and install Waterblocks! Otherwise its a waste of time n $$$!
....But the Cards CAN be OC'd well beyond FTW speeds SC speed is 797Mhz....no problem running 100% stable at 850Mhz with Stock 1.088v
You are welcome to come over and have a look and listen. I can run Furmark, I just ran it for a little bit, didn't top 50C. Fan didn't go above 50%, like I said, it is set to match temp.
I did mention the case temp in the post above, yes, it goes up, but not to a terrible amount.
I could try running Shogun 2 DX11 and see where it settles out, or Skyrim if you like, or Fallout NV. I don't have Crysis, Fear or BF3.
If you want to come over send me a PM... I think I have some beer in the fridge. I know I have some wine left, or some Crown in the cupboard... you would have to bring your own mix for the Crown (if you like mix).
Dwayne's Rig - Asus Prime Z370-A : i7 8700k : Corsair Vengeance 32 GB DDR4-3000 : Corsair RM650x PSU : Corsair H100i V2: Fractal Design Meshify C : EVGA GTX 1080 :
HTPC - GigaByte H67MA-UD2H : i3 2100 : 8 GB Mushkin Silverline Stiletto : Antec TruPower 550W : : Corsair H100 : Sapphire HD 6670 : Corsair 650D: Kingston 60 GB SSD Boot
Tablet - Samsung Tab A 10.1"
Wife's Rig - MSI GL72M 7RDX
  #22 (permalink)
Old February 5, 2012, 01:07 AM
I also find that hard to believe though, maybe a few screen shots of GPU-Z's sensor tab while it's running?
that's extremely cool even for an aftermarket cooler I'm thinking!
  #23 (permalink)
rjbarker's Avatar
Sounds good....that AFMCooler sounds quite impressive, I'm just finishing off the last of my Rum ;) Been trying like hell to climb past a guy n 3DMK11 who's sitting at P14008.....fvck me...hit P14K, anymore and I Blackscreen!!!
Really, that is impressive that your cooler can keep Temps that low, wouldn't work for me running more than one Card though...
To the OP...if your running a single 580 then perhaps take a look at what Dwayne is talking about...sounds quite impressive!
Sorry Dwayne ;)
Firestrike Extreme: 21.452
MARK 11: 32.530
  #24 (permalink)
Old February 5, 2012, 06:20 AM
Alpine's Avatar
I,ve play a couple hrs last night at BF3, if i leave the fan on auto, temp reach like 85c and maybe more and then the fan is starting (and stop few sec after) and sound is extremely loud. I've play with fan and set it to 70% and i was at 72 and the fans ound was ok my ears.
Main system
|I7 3930K|Asus P9X79 WS|2X Evga GTX 690|Samsung 256G Pro|H100|Dominator Platinium 16GB 2133Mhz|AX1200|540 AIR|SP2500|Vengeance 2000|IBM PRO/1000 PT Quad Port|
Server system
|I7 3820|Asus P9X79|12G G.Skill 1600Mhz|Noctua NH-D14|Force 3 120GB|LSI megaRAID 9261 8|RAID5 5X 3TB|AX650|Fractal Design Arc Midi|IBM PRO/1000 PT Quad Port|
  #25 (permalink)
Old February 5, 2012, 11:21 AM
Dwayne's Avatar
Just played a scenario in Shogun 2, DX11 most settings Ultra and my temp topped out about 58C. Took about 30 min to win the scenario :) Like I said, fan profile is set linear so the temp and the fan are the same.
EVGA GTX 470 Question Kommie986 Video Cards 7 September 2, 2010 08:13 PM
Evga 295 - Question for gamers Stark.tD Video Cards 16 February 12, 2010 08:20 PM
EVGA GeForce GTX 295 question. Schnerf Video Cards 10 July 29, 2009 04:36 PM
EVGA step up question Realityshift Off Topic 9 April 25, 2009 11:15 AM
Question (EVGA 8800 GT SC) AnthraxAdrian Video Cards 12 April 21, 2008 05:37 AM
