Old February 1, 2012, 05:44 PM
Default GPU Screws
In the process of replacing the TIM on my 5870, mostly stripped the heads of the factory screws. Does anyone know where to get some replacement or better screws?
Old February 1, 2012, 07:51 PM
techman95's Avatar
i hear Canadian tire has screws that work perfectly. but i wouldnt know personally since i dont live in Canada
Amd....definitely a blond female.....not much on the cpu side, but always strutting about showing off her gpus
Old February 1, 2012, 08:17 PM
supaflyx3's Avatar
I don't think Canada tire would have those types of screws, you might have to buy an old stock cooler, probably wouldnt cost more then $20
Old February 1, 2012, 09:24 PM
how on earth did you strip those?
Old February 1, 2012, 09:48 PM
I partially stripped the heads, not the threads
Old February 2, 2012, 06:47 AM
norfolk's Avatar
You may want to give these guys an e-mail to see,They may be able to send you some.
SAYAL Electronics Action Catalog Index - 2/2/2012, They have everything electronic
Old February 2, 2012, 09:40 AM
do you know the thread size or pitch?
do you have a picture?
-joe
Old February 2, 2012, 09:57 AM
Soullessone21's Avatar
PM me I have some :)
Old February 2, 2012, 10:03 AM
Adzsask's Avatar
Default my gf works at Canadian awesome
In fact , they do have screws that work perfectly, I also used to race electric/nitro RC cars/4X4 trucks, and thay have one of the best selections of small, and fine threaded items in my city. So so hard to find the little hex headed set screws that hold my 1/18th scale electric RC's axles onto the driveshaft(4X4 truck,8 inches long, does over 75MPH), Canadian tire even stocks them.
Rad screws? Birk Water Cooling 13 January 8, 2012 10:07 PM
M4 screws SugarJ Water Cooling 10 December 5, 2011 07:14 AM
where to buys screws and what not Goalieman077 Cases 3 January 7, 2010 03:32 PM
[WTB] Stock HS w/screws for 8800GT/GTS , or Just Screws! Soultribunal Buy/Sell & Trade 15 October 29, 2009 01:48 PM
help with screws phantom_jo Off Topic 9 May 7, 2009 09:41 AM
