Old February 12, 2012, 08:16 PM
$100 for a 460 768mb maybe. But whatever you do, do NOT get a 520
Old April 21, 2012, 01:11 AM
I'm just bumping this to ask a question.
Are the current 560s just re-modified 460s? I mean, are the heat sinks the same?
I found some 460s FS and I was hoping someone here could compare them.
MSI Cyclone gtx 460 1gb
PNY gtx 460 1gb
The PNY sends the heat out of the case while the MSI card's cooler design doesn't. What does that mean? If I have sufficient cooling with my case fans, it wouldn't be a problem? Or?
I think I'd probably lean towards the PNY card. I think both sellers will ask for $100+ shipping. Is that a good price for a 460 card now? I noticed newegg had the 460 1gb for $109 w/ free shipping but it's listed as 'out of stock' and probably won't ever return. I wasn't even going to look for these cards but it's not a bad deal? I was going to buy a 550 or 520GT to use as htpc until prices went down further.
But, the 460's idle temps and power consump. isn't too bad. Any comments?
Old April 24, 2012, 09:32 PM
monkey_mo's Avatar
buy my 560ti for only about $65 more LOL, okay no more self advertising. IMO a $100 for a 460 is kinda a lot now, i would only pay up to $85-90 for one. A 6870 is imo a lot better than a 460 and you can pick them up for $130ish, a 560Ti/6950 are another ~20% faster than a 6870 and you can pick them up as low as ~$170ish. My 2 cents.
RAM Prices? bkh2 RAM 1 December 16, 2010 08:39 AM
Gas Prices Beermaster Off Topic 78 November 22, 2010 11:08 AM
Gas Prices Chos3n Off Topic 114 June 18, 2009 06:16 PM
Possible GT200 Prices??? werty316 Video Cards 8 June 11, 2008 08:48 PM
AMD Likely To Cut Prices Further Babrbarossa Press Releases & Tech News 3 March 20, 2007 02:31 AM
