Upgrading from 8800 GTS 320MB My system is a Q6600 quadcore CPU, 2GB ram. Currently have a 8800 GTS 320MB card. Have not been doing much gaming, but lately started getting into Skyrim, and kids are asking about some games like batman arkham city. I play skyrim on a single monitor at 1080p, but with my current setup get stuttering on anything higher then the 'low' setting. Would love to set it to ulta-high and play with some of the texture mods available. Any suggestions on cards to look at? don't want to spend more then about $200. Something with batman arkham city bundled would be even better. Will likely do a major upgrade in the Fall, and be looking at the next gen of CPU/GPU then. |
Either a 6870 or 560, i'd push the budget up to $240 and grab the least expensive 560 Ti myself. |
Make sure not to upgrade too high on the video card. Q6600 will be a bottleneck to newer cards. |
Thanks for the suggestions. Looking at a used 560 ti someone local is selling. The Q6600 is overclocked to 3GHZ. Do you think it will be able to keep up with that GPU? |
First off I would say go for a gtx 560. Secondly you only have 2gb ram and that may be as big of a problem as your video card. I suggest going to atleast 4gb total (so grab another 2gb stick if you have a single stick of 2gb now or if its 2x1gb sticks grab 2x2gb or 2x4gb depending on the deal you can get on it and what your motherboard supports). If it was my computer and budget was a constraint I would say a gtx 560 and some more ram over a gtx 560Ti (that said if you can swing the Ti and the ram that's even better). |
If you can buy the used GTX 560Ti great if not pick one of these up at new egg Newegg.ca - PNY VCGGTX560XPB GeForce GTX 560 (Fermi) 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card Newegg.ca - MSI R6870 Hawk Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity and then buy some more ram, at least have 8GB of ram what are your system spec |
More ram = a happy computer. Start with that and see how it goes. It's just so cheap right now... |
Memory would be good, but this uses ddr2-800 RAM which is not so cheap (compared to what DDR3 is going for). I don't want to throw too much money into this system, as I plan to upgrade in the next year. Current system is: Q6600 running at 3Ghz Abit IP35 Pro motherboard OCZ DDR2-800 RAM (2x1GB) 120GB SSD drive 3x2TB drives in RAID5 for storage Antec Sonata Designer 500 case with 500W earthwatts power supply My other concern is if the power supply will be enough to handle the new video card. If I can get that used 560 ti, I may look at getting a more heavy duty power supply that I can eventually move to the new system. Maybe pickup a water cooling solution too that can move from current 775 socket to 1155. Can see if I can get the CPU higher then 3GHZ then. Also running windows 7 32bit, so anything more then 4GB and I need to do a reload to 64bit. |
Bit of a sticky wicket yeh? Sort of caught between a rock and a hard place imo. You definately need to upgrade but where do you start exactly would be the question. I reckon you might wanna try and pull the trigger on something now and save yourself some probable annoying hassles. Soulstone is selling a complete system OBO for around 400 dollars. But I'm not sure if it comes with a psu. http://www.hardwarecanucks.com/forum...und-tower.html This would run the games you want much better. It comes with win7 64 bit which is easy enough to extract the cd key and find the coresponding disk for future re-installs. He also has a bunch of ram forsale too. The 32 bit OS is really going to hinder you and I really wouldn't throw money at your current rig as you've pretty much hit the wall with it. I have never had anything but problems with Antec PSU's and I would also worry about it not liking a new more powerful vid card like the 560. It if pops then what? |
Sorry I missed that you were going to be doing a new build next year. Your power supply is good, but I don't know if I would run an OC Q6600 and a gtx 560Ti together on it (that will be quite a bit of power). It all comes down to how much you want to invest in your current rig. I would say try and grab 2x1gb ddr2 (preferably used and cheap) and that would be it for non-reusable investment. After that go for GTX 560/560Ti and a corsair/seasonic/xfx/antec 650w power supply when you can afford it. Both of those could be carried over in to a new computer. |
| All times are GMT -7. The time now is 04:20 PM. |
