Old January 17, 2012, 01:33 AM
Exclamation Eyefinity - DP to HDMI ? Help Plz
Hey I was wondering if I purchased something like this,
Newegg.com - PowerColor PCS+ AX6970 2GBD5-PP2DHG Radeon HD 6970 Call of Duty Edition 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
Or
Newegg.com - XFX HD-697A-CNFC Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
Can i support 3 monitors and an Eyefinity setup with this Card, using the HDMI, a DVI to HDMI, and DP to HDMI adapters?
Would I need a DP-to-HDMI Active adapter, or will a passive one work as well?
I don't understand why all the videos I've seen always use DVI x 2 , and DP-to-DVI.
They seem to always connect DVI, why not the HDMI?
Thanks!
Old January 17, 2012, 02:22 AM
Supergrover's Avatar
I believe you need a active adapter, IIRC the info is in this thread.
Official ATI Eyefinity/nVidia Surround Discussion Thread
R.I.P.
Old January 17, 2012, 03:49 AM
Thanks for the reply, found some useful info on that thread.
In addition, would I be able to run a second card - RADEON HD 4870 2GB x2 edition - Card along with the 6970 HD 2GB ?? without Crossfire , or does it not boost any performance without the crossfire enabled?
Old January 17, 2012, 07:05 AM
Jebusman's Avatar
It won't boost performance, because it won't get used.
Old January 18, 2012, 10:10 AM
Manufacturer Rep
There is this card in the same price/performance range but with 4 DVI ports instead of DP:
Newegg.com - Galaxy 57NKH3DH5PXK MDT X4 GeForce GTX 570 (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Multi-Display Video Card
Old January 18, 2012, 10:28 AM
Arinoth's Avatar
I believe the AMD card would still perform better as it has 728MB more of vRAM which is very important at 5670 x 1080 or higher resolutions.
At the moment I do not believe there are any inexpensive active display port to hdmi adapters. I know there are DP to DVI which run about 30$. You could try using that with a DVI to HMDI adapter ontop of that, though don't know how much this will effect the signal quality.
Here I am: here I remain
LAPTOP HDMI TO LCD TV HDMI NOT WORKING appplejack Display Units 15 May 3, 2014 11:15 AM
Eyefinity Livestrong Troubleshooting 5 August 8, 2011 06:07 PM
Completed SB P67 + Eyefinity writhen Case Mods, Worklog & Gallery 4 February 10, 2011 01:47 PM
Got my Eyefinity going on!!! ontariotl Video Cards 68 October 17, 2010 03:17 PM
eyefinity ... tzetsin Troubleshooting 3 May 3, 2010 08:57 AM
