Old January 19, 2012, 12:34 AM
Supergrover's Avatar
Originally Posted by sakage.shinga View Post
I'd prefer not to touch the voltage. Guess I might bump the core up to 925 and give it a try.
What would you do in the case of hearing the rattling noise? The shroud?
Both of mine suffered from a rattle at higher fan speeds starting at 60-62%, the shroud and the sink were making a slight contact with each other. Simply running your hand along the shroud should show where it is contacting then a slight bend by hand, like 1mm here not alot and it goes away.
Yours could be perfectly fine I know a few ppl that dont have this issue at all.
Stock fan settings suck though IMO but check it out you might find them acceptable.
R.I.P.
2 x XFX 6970 2gb and Asus P8P67 Deluxe. canada2005 Price Check 1 December 29, 2011 11:58 PM
asus 6970 direct cu ii kyle_L Price Check 1 December 20, 2011 06:47 PM
Asus Radeon 6970 DirectCU II crossfire n0y Video Cards 2 November 5, 2011 11:02 AM
Asus EAH5850 Radeon HD 5850 DirectCU T or Asus ENGTX460 DirectCU GeForce GTX 460 1GB tfy Video Cards 12 February 23, 2011 11:42 AM
ASUS 3-slots Direct CU 6970... Delavan Video Cards 5 January 8, 2011 12:08 PM
